Old 09-30-2014, 11:25 AM   #1
LuckyLightning
LuckyLightning's Avatar
Tachometer install in '62 235?
Hi guys, I have a very basic understanding of how a tachometer is typically installed - somewhere on the ignition coil? But I've also been reading what I think is that only '63 and up can run as-is but '62 and below will need a separate sending unit?
I have a Stewart-Warner tach (just like this one on ebay) that I picked up from a local salvage yard. Has 4 wires, which I assume are for: ignition switch power, dash light, ground, and ignition coil (or wherever it hooks up to the engine).
Would really appreciate some guidance for how to install this: where does the wire (that goes under the hood to the engine) connect on a 1962 (C20) 235 inline 6? Do I need a separate sending unit?
Thanks for reading.
Michael
- 1962 C20 LB stepside (project thread) - sold
- 1963 Chevy C10 LB stepside (donor)
- 1963 Chevy C10 LB Custom flatbed (project thread) - sold
- 1979 K20 LB fleetside (project thread)
Favorite exchange on the board so far:
ol_Curt: "Jason, do you have power steering?"
jason65: "No, but I lift weights."
LuckyLightning is offline   Reply With Quote
Old 09-30-2014, 12:48 PM   #2
Figuarus
Figuarus's Avatar
Re: Tachometer install in '62 235?
If your wires are color coded like all other tachs, You should have a green for signal (positive side of the coil) Red for switched power, black ground and white for lights.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 09-30-2014, 02:59 PM   #3
LuckyLightning
Thanks, I understand that - my question is where do I connect the green wire? To the top if the ignition coil (same point of connection that goes to the distributor cap)? Do I need a separate sending unit for my 235?
Michael
Old 09-30-2014, 03:01 PM   #4
Figuarus
Figuarus's Avatar
The signal wire goes to the positive side of the ignition coil. (the nuts on either side of it, look for the positive side)
NOT the output wire that goes to the distributor.
2013 Malibu LTZ
Old 09-30-2014, 07:07 PM   #5
LuckyLightning
Awesome, thank you!
Michael
Old 10-01-2014, 12:28 AM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
You may want to confirm that the green wire goes to the "positive" side of the coil. It is my understanding that the green wire is connected to the "negative" side of the coil.
I would double check this and make absolutely sure. Connecting the green wire incorrectly will damage the tachometer.
The separate sending unit you are referring to is for the factory installed Sun made tachometers and is not needed for the style you have.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 10-01-2014, 04:10 PM   #7
Figuarus
Figuarus's Avatar
Tbone is right. I apologize. The green wire is on the negative side.
2013 Malibu LTZ
Old 10-06-2014, 12:03 AM   #8
LuckyLightning
Thanks guys, I will connect it to the negative instead.
Michael
