Ligenfelter crank trigger conversion
http://www.lingenfelter.com/mm5/merc...3#.VCswFsu9KSM
Why would you need to run this on a swap? I see what it is for but if your are running a stock gm ECM that would negat the need for the conversion box correct? I'm assuming this is for someone running a 4.8 on a 5.3 ECM or vice versa? |
#2 | |
Re: Ligenfelter crank trigger conversion
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
That's what I thought. I'm currently doing a lq9/4l80 swap on mine. I was looking at a buddies 74 jeep that he did the 5.3/4l65 swap on and he was running that. But he is using stock management so just kinda made me think why? He had a shop do it and they told him he needed it.
i was following a thread on HPT forums where it looks like they were gonna add code to make the switch in the OS, but it dead-ended.
about your buddies swap: i dunno why they wanted the box. maybe they needed to make a DBC OS work? I met a local guy that did just that…but he was getting ready to swap reluctors b/c the lingenfelter box was a turd. Caused multiple fails per week in his 5.3 swapped toyota wagon. |
yeah thats what he his running but they can program that out correct? or use a dbc computer.
There are no DBC Gen4 applications, so if he was running a 2008-up 5.3, and wanted to run DBC, that's why they used it, hes running a Gen3 PCM with a DBC tune. You cannot tune the DBW out of the newer ECMs.
thats what i figured but you cant write that out of the PCM? just payed attention to the end of the post nevermind. thanks guys for the info.
so the takeaway here is if you have gen4 and want to do a DBC, the best fix is to change the reluctor wheel.
correct me if i'm wrong. thanks. |
