Rear Heavy Duty Coil Spring Question
'72 3/4-ton with Heavy Duty rear coils per the SPID (and visual inspection). I found a set of 1/2-ton rear coils from a '72 for next to nothing. I know the ride will be nicer but will it drop the rear at all? I'm not too concerned about the ride quality (it is FIRM but not terrible) but would like to drop the rear. May consider drop springs or blocks but would like to use the 1/2-ton springs if they will drop it at all since I've already got them. It has a serious rake to it and I'd like to level it out a bit!
Thanks.
1972 GMC 2500 Custom, 96K miles, Purchased New By My Grandparents 2016 Toyota Tundra TRD Off-Road SR5 1993/2003/2005 Toyota Land Cruisers 2004 Corvette Z06 / 2000 Covette Coupe 2006 Ducati Multistrada 2014 BMW X3 XDrive35i M Sport Last edited by harrydunn; 10-01-2014 at 12:52 AM. |
Re: Rear Heavy Duty Coil Spring Question
ttt
1972 GMC 2500 Custom, 96K miles, Purchased New By My Grandparents 2016 Toyota Tundra TRD Off-Road SR5 1993/2003/2005 Toyota Land Cruisers 2004 Corvette Z06 / 2000 Covette Coupe 2006 Ducati Multistrada 2014 BMW X3 XDrive35i M Sport |
Moderator
![]() Join Date: May 2007
IMO they won't, since they are the same height and not drop springs. But since you already have them why not give it a try and see what happens?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
![]() Join Date: Oct 2011
To my recollection, the 3/4ton frames have a slightly larger section modulus..which makes the frame slightly 'taller' than the 1/2 ton frame.
These means, all things being equal, the truck will generally sit a little higher as a result of this. Now, I'm not sure how the lengths of the coils differ...if they differ. From a glance you would think the 3/4 ton coil would be slightly higher (and heavier duty) to carry more load and to reach up a bit more. ....just thinking out loud here. Either way, I'd try it out....I think it would work and I think the rear height would settle down a bit and give a little better ride. my two bits. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
The Older Generation
I took the heavy duty coils out of my Suburban and put 1/2 ton progressive coils in it. It was originally an ambulance. Made all the difference in the world in the ride. Smooooth.... and it dropped it down a little. LockDoc
Man, oh man. PB Blaster and my impact wrench are not budging the lower spring bolt. Put my cheater bar on it and I know I'm going to snap it so I'm laying off it for now. May take it to my mechanic friend and let him snap it off for me since he can fix it easier. :-) Tried the U-bolts for giggles with a cheater and 18" pipe and could not budge them.
Something I was surprised about: Rear springs are both only bolted onto the trailing arms. They are not bolted on top to the frame. Normal for a 3/4-ton with HD springs? Truck has been in my family since new and I can't imagine the rear springs ever being tinkered with. My grandfather and I are the only two owners. ![]()
Thoughts on the rear springs not being physically connected to the frame at the top?
Thanks.
![]() Join Date: May 2010
They should be attached using cups like the bottom. My cups were mostly rusted away though.
Vintage 4x4s
Yes, you are missing the cups to bolt it to the frame on top. You should see holes for a bolt there to mount the cups. I will try for a pic
Unless your truck is super rust free, a torch is really the only way to get any bolt that goes through the trailing arm out. Heat the arm along length of bolt.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Anyone care to chime in on that? |
Here's a picture of my 69 3/4 ton with original coils. Looks progressive to me.
#13 |
#14 |
Another picture below that I found that shows the edge of the retainer cup and the bolt through the frame. Also, here's a link to the cups I bought from CPP. However, the bolts supplied are too short. http://www.ebay.com/itm/1963-1972-CH...df9ec2&vxp=mtr
