Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-01-2014, 01:02 PM   #1
MikeS.
MikeS.'s Avatar
Clam shell hinges
Anyone carry new hinges? Do the 67-? Hinges work? I could use all four new hinges.
I looked at the truck shop.com and don't see any hinges for our series of trucks.
Thanks guys.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 10-02-2014, 12:30 PM   #2
MikeS.
MikeS.'s Avatar
Re: Clam shell hinges
Really? No one knows anything? I'm surprised.
Past Master
Old 10-02-2014, 04:47 PM   #3
lucifer
lucifer's Avatar
Cool Re: Clam shell hinges
I couldnt find anything new. I do have an extra set if uppers for sale.
They may need some attention
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 10-02-2014, 11:29 PM   #4
padresag
what is the problem with what you have?
ron
padresag is offline   Reply With Quote
Old 10-03-2014, 12:28 PM   #5
MikeS.
MikeS.'s Avatar
Ron, they are loose and let the panels sag. The window droops on the right side and rubs the tailgate. Pretty much the same thing with the tailgate it has damaged the outside sheet-metal. Evidently it was operated for years without straps to hold it when it was down.
Past Master
Old 10-03-2014, 12:29 PM   #6
MikeS.
MikeS.'s Avatar
What kind of attention? Cleaned up and painted or?
Past Master
Old 10-03-2014, 02:59 PM   #7
padresag
you can rebush the hinges and new pins will tighten that part up. sometimes the sheet metal where the hinges reside can get get stretched and that can be repaired
Doubt that you'll find a set of NOS hinges so they would have to be rebushed what ever else that you found. just like door hinge pins and bushings
ron
Old 10-04-2014, 03:08 AM   #8
MikeS.
MikeS.'s Avatar
Thanks Ron, I found where I can buy new bushings and pins.
Past Master
Old 10-04-2014, 11:01 AM   #9
perro13
perro13's Avatar
Where did you find pins & bushings. Thanks
perro13 is offline   Reply With Quote
Old 10-06-2014, 02:46 AM   #10
MikeS.
MikeS.'s Avatar
Truckandcarshop.com
Past Master
