Old 10-01-2014, 06:55 PM   #1
62much
62much's Avatar
Disc Brake Center Bore Question
Just bought a 69 C10 that the PO put a disc brake conversion on, or at least tried to... but that's a different story. My question is, I'm trying to find 6-bolt 5 or 6 spoke wheels, but all the center bores are to small, do I need to worry about the center bore with disc. brakes, or is that for just Drum Brake trucks??? and, how about the rear drums???
Thanks,
Clay
62much is offline   Reply With Quote
Old 10-02-2014, 07:20 AM   #2
PGSigns
PGSigns's Avatar
Re: Disc Brake Center Bore Question
When I did the conversion on the 65 I did not have a problem with later model wheels on the front using the aftermarket 6 lug rotors. I did have a problem in the back. I pulled tha axles and set them up in the laithe and cut them down tot he late model size. I left a small section to center the stock drum.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
