Small Block 327 issues
Hey Guy's,
Sorry about the stab in the dark but been having issues with my pig(c10) motor. I have a 327 s/b and when i get the motor to turn over, i have to keep my foot on the gas otherwise it stales, same thing happens when after ive kept reving the motor to warm it up. i have managed to get it to idle once, the motor sounded like it had a lumpy cam (no engine mods have been done to the motor) then stalled with a big back fire out the exhaust. Things ive done to try and fix. Replaced fuel filter. checked all spark plugs and leads. Atm the moment im stumped and would love any input you guys might have.. chips29 |
Re: Small Block 327 issues
If it was running ok then it sounds like a rebuild on the carb may be in order.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Sounds like a big vacuum leak. Look for carb gasket, PCV hose and brake booster if you have them.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: Dec 2013
Vacuum leak has my vote .
