1960-1962 vs 1963-1966 fleet side bed differences
What is different about the fleet side bed cross members from a 60-62 truck vs. a 63-66 truck? Most of the parts catalogs list them separately. I'm converting my 63 step side to fleet side and I'm not sure what year fleet side bed i have.
![]() Join Date: Jan 2011
Re: 1960-1962 vs 1963-1966 fleet side bed differences
The location of the cross supports are different for one. The 66 I have has the early bed strips in it from Mar-K and some of the holes dont line up. When I redid the wood it took a bit to figure that out.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
The frames are wider on 60-62. So the frame holes would be wider, especially the rear most one with angle perches. Goto faq section lots of info and threads on this.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
the 63-66 frames are the same. the 60-62 are the same. I believe the 60-62 are 42" wide and the 63-66 are 34" wide, I will double check that tonight.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Feb 2013
Scored on a "brand new" 1986 GMC takeout bench for '65 GMC
No Weak Links ![]() |
