10-02-2014, 10:21 AM | #1 |
How far before C-notch?
Starting to plan to lower our '60 short fleetside. How far can we go before a c-notch is necessary? The only thing we have coming so far is a set blocks - forget if they are 1.5 or 2", thanks-
10-02-2014, 10:23 AM | #2 |
Re: How far before C-notch?
I have 5" in my 66 with no notch. I just trimmed the bump stop.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-02-2014, 11:58 AM | #3 |
Bags aired out, shocks and bed wood limited. So 6 to 7 inch. I am still not all the way inside notch.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
10-02-2014, 03:33 PM | #4 |
At 5", you're OK but just don't overload the bed with weight. At 6", you are super-close and you have to be careful when you drive it and you'll still hit the bumpstops on occasion. At 7", you have to notch it.
I'd play it safe, and as LVPhotos says, run a notch if you're at a 6" drop or lower.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
10-02-2014, 10:13 PM | #5 |
My 65 is at 5" in the rear but i use it as a truck so had to c-notch.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
10-03-2014, 06:07 AM | #6 |
I'm at 4 inches and have no problems. I can haul small loads without any issues.
66 shorty |
