Rochester B Throttle Help Anyone?
It appears that my screw became loose or wasn't tightened by the PO and the spring on what I'm going to call my throttle lever worked its way loose. One side of the spring goes around the throttle level but what does the other side of the spring attach to?
My Jalopy - http://67-72chevytrucks.com/vboard/s...d.php?t=641102 |
Re: Rochester B Throttle Help Anyone?
I assume the spring attaches to the level like this just from zooming in on some pics around the internet, but no clue what the other side goes around to put load on the spring...
Backside of carb...
ill post a pic of mine when i get home from work.. i cant remember off the top of my head.
Alrighty thanks. Anyone else?
Check out this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=570390
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
If I recall correctly, you have the spring on the throttle arm in the correct position, you just need to attach where it's circled in red and make sure that you got tension so the top of the throttle arm is pushing against the choke lever.
My truck ain't dead, it just smells funny. |
...and the screw, even when tight, should allow the lever to rotate freely--not locked down.
Sam |
Sorry it took so long.. wouldn't let me upload for some reason. Loop the smaller hook around the little arm on the carb and then position the bigger one on the throttle arm, then you'll have to push the arm and flex the spring to get it on the screw mount.. if that makes any sense. The spring should be under tension.
here is a pic of the same carb
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
