Old 10-02-2014, 10:00 PM   #1
Sweet Willy
Sweet Willy's Avatar
At my wits end and then some...
Pictured below is the steering wheel I have in the '54 Chevy truck. Also pictured below is the horn contact spring unit that is supposed to fit. It doesn't and I don't know why. The contact spring unit is 1 3/4" long and from what I can figure out I need one that is 2 1/8" long. Tried to jury rig it and burned up the horn. Literally. Had to pour a can of soda on it to put it out. Any suggestions?
I don't have a bucket list but my "F....it" list is a mile long.
http://67-72chevytrucks.com/vboard/a...1&d=1411272730
Sweet Willy is offline   Reply With Quote
Old 10-03-2014, 08:38 PM   #2
rrenner
rrenner's Avatar
Re: At my wits end and then some...
I had the same issue, did some research and found the same looking contact but with one pin much longer. Look at www. zip-corvette.com. I'm kinda cheap so I took the plastic housing apart (top snaps off) cut the threads off a brass bolt and filed down the head to match the shorter one it came with, works great.
rrenner is offline   Reply With Quote
Old 10-03-2014, 10:00 PM   #3
Donaldo
That's Not being cheap - it's custom adaptive fabrication.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 10-03-2014, 10:47 PM   #4
tmoble
What Don said. right at the root of hot-rodding IMO.
Glad you posted this Sweets. I just bought a repop wheel like that, now I'm forwarned about issues. Thanks.
Were you following right behind a large group of Hells Angels when the horn got stuck on?
tmoble is offline   Reply With Quote
Old 10-03-2014, 11:06 PM   #5
Sweet Willy
rrenner, I did the same thing you did but I guess not as well because that's what caused my horn to burn up. But, thanks. I ordered the one from Zip-Corvette in spite of the cost.
Tmoble - nope I was in front of them but they couldn't keep up with me!
