Old 10-03-2014, 04:14 PM   #1
chevytruckguy70
1/2 ton vs 3/4 in cab fuel tanks
I just bought a 71 3/4 ton 2wd truck that hasn't been started in 8 years. The entire fuel system must be replaced due to the great fuel we have to work with these days. In looking at a new tank I can only find 1/2 ton tanks. I didn't know there was a difference.
I know there's are different versions due to the emissions but is that the only issue I have to worry about?
Can someone shed some light on this for me?
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI.
2007 Chevy 2500HD 4x4 Duramax
1970 Chevy K20 (SOLD)
1972 Chevy C15 (1/2 C10, 1/2 c20)
1970 Chevy C10 (parting out)
chevytruckguy70 is offline   Reply With Quote
Old 10-03-2014, 04:30 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: 1/2 ton vs 3/4 in cab fuel tanks
There is no difference between 1/2 and 3/4 tanks. 72 tanks had EEC but that is the only difference I am aware of.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 10-03-2014, 04:34 PM   #3
chevytruckguy70
Thanks for the reply. I'm going to go ahead and buy the 1/2 on tank but both companies I talked with said they will only say it will fit a 1/2 ton. Both said they are looking for a 3/4 ton supplier but cannot find one.
Thanks again.
Old 10-03-2014, 04:43 PM   #4
Nitis
Nitis's Avatar
I don't know what your ultimate goal is but have you considered relocating it inside the frame?
If not I'm sure you could source a good one someone has pulled
Nitis is offline   Reply With Quote
Old 10-03-2014, 04:53 PM   #5
chevytruckguy70
I've thought about it but I'm kind of a purist on the old trucks.
I may try to coat the tank and reuse it but its pretty nasty. The sending unit has rusted so much it was hard to get out. I've never seen one do this before.
Old 10-03-2014, 05:18 PM   #6
In The Ten Ring
You might want to try a Spectra tank from that outfit in Canada. I nearly bought one myself but I ended up having my tank cleaned and "renewed" at a radiator shop. I'd also try GMC Pauls and Classic Heartbeat.
If you want to stay original, I'd suggest getting a tank off of a member. Several people on the boards have their old tanks and might just give those away. I'd get it shipped in a wooden crate though.
In The Ten Ring is offline   Reply With Quote
Old 10-03-2014, 07:21 PM   #7
john
member #16
john's Avatar
Did the 3/4 ton trucks have EEC? I know they didn't have smog pumps. At least not in CA.
john is offline   Reply With Quote
Old 10-03-2014, 08:51 PM   #8
Mayo
Cool Truck
Mayo's Avatar
I believe I remember reading that the 71-72 3/4 tons use the older non EEC type tank where as the 1/2 tons switched
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 10-04-2014, 09:32 AM   #9
1972BlueC20
1972BlueC20's Avatar
Yeah 3/4 ton trucks have NON EEC tanks. They use the same tanks as 1/2 ton trucks. Classic parts sells them for $150
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 10-04-2014, 07:11 PM   #10
jocko
jocko's Avatar
concur - 3/4 ton trucks were non-EEC through at least 72. If you are installing a 1/2 ton tank from a 70-72 (I BELIEVE those were the trucks with EEC), make sure you use the correct filler neck grommet. I am pretty sure the EEC tanks had a 2" i.d. grommet whereas the non-EEC tanks had a 1/5" i.d. grommet. However, IF this were the case, I find it hard to believe that nobody carries a "72 3/4 ton tank".... LMC sells a 67-72 non-EEC tank and that should meet your needs - and note that they do NOT state 1/2 or 3/4 ton for the non-EEC listing, whereas they do list a 70-72 EEC "1/2 ton" tanks separately. Personally, I'd still lean toward rebuilding or finding a decent one in a junkyard and coat the inside. Nothing (for me) ever seems to be "quite right" when I order stuff like this from LMC or several other mfgrs. It is just a tank, so I think that with the correct grommet, as long as you purchase a non-EEC tank, you should be good to go.
Old 10-04-2014, 07:20 PM   #11
FirstOwner69
FirstOwner69's Avatar
Try Rock Auto. They sell Spectra Premium, which has received favorable comments on this forum, at a pretty decent price. I don't have any personal experience with them, however.
FirstOwner69 is offline   Reply With Quote
Old 10-05-2014, 01:06 PM   #12
chevytruckguy70
Thanks everyone for the replies. I' m going to "renew" my tank and hopefully that works out.
It is a non-EEC tank, I do know that for sure.
This truck is from central Ohio and winters has played hell with the fuel and brake lines. I'm going to start a new thread with some questions about that.
Thanks again!
