Old 10-03-2014, 07:07 PM   #1
buckroseau
Narrowing a 68/newer 3/4 ton rear axle, anyone done it?
Just like the title says.
68 or newer 3/4 ton rear axle for a 2wd truck. From my understanding the 68 and new axle is 1.5" wider than the 60-66 rear axle. I've got a 62 C20 and I'm wondering if this is an option.
I know narrowing axle's isn't anything new. I'm just wondering if there are any surprises where the splines couldn't be milled on the shafts after they were cut 3/4 of an inch on each one?
I would keep my rear axle but it is a 4.57 ring and pinion, and from what I have found out, lower ring and pinions are just not available. A 68 or new axle would get me into 3.60 or 3.70 option area. And rear C20 axles are fairly cheap to pick up.
Thoughts?
Thanks, Matt
buckroseau is offline   Reply With Quote
Old 10-03-2014, 08:08 PM   #2
PGSigns
PGSigns's Avatar
Re: Narrowing a 68/newer 3/4 ton rear axle, anyone done it?
You may find the extra width is not an issue. Several members have doe the swap on 60 to 66 trucks with out any problems. There are Several threads on it here. Here is a good one.
http://67-72chevytrucks.com/vboard/s...hlight=14-bolt
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-03-2014, 08:13 PM   #3
buckroseau
Jimmy
I thought of that to, but these tires are right on the edge of touching the inner lip of the box side now.
I just thought maybe someone had already done it. I was curious as to if the axle shafts were straight, so that there was enough meat still there to cut an additional 3/4" of splines. Or, if they tapered off after the spline. I suppose a person could just shorten one side as well, and just cut 1.5" of spline in one shaft and leave the other side alone. It would save a lot of work and cost.
Matt
Old 10-03-2014, 11:17 PM   #4
Captainfab
60-66 Nut
The Eaton HO52 in the C/K20's and C/K30's don't follow the same width differences as the C/K 10's. The Eaton under your truck should be 65.5" wide. There is a member here that put a 2000 14 bolt from a 3500 truck that measured 65.625" wide. Narrowing a full floater differential gets expensive since it is more time consuming than narrowing a semi-floater.
Old 10-03-2014, 11:25 PM   #5
buckroseau
I'm all about easy. What years of the 3500 would work? And what was the ratio?
Matt
Old 10-03-2014, 11:40 PM   #6
66Submarine
66Submarine's Avatar
The common 14 bolt replaced the Eaton in 1973, not 1968. There were a few trucks with Dana rears as an option starting in '68.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 10-03-2014, 11:47 PM   #7
buckroseau
Would a 2500 work in that year as well?
Matt
Old 10-04-2014, 01:40 AM   #8
Captainfab
60-66 Nut
That I do not know since I did not do the conversion I mentioned. Here is the thread for you to read thru.
http://www.67-72chevytrucks.com/vboa...olt+conversion
The link that PGSigns posted is a good one as well.
If you think you really need to have a differential narrowed, I wouldn't waste my time or money on an Eaton HO52. I would go with either a Dana 60 or a 10.5" 14 bolt. You might get lucky and find a Dana 60 from a '68-'72 C20. Then all you would have to do is move the trailing arm mounts to bolt it up to your '62
Old 10-04-2014, 10:11 AM   #9
Budman56
Budman56's Avatar
what about a different offset in the wheel instead of modifying the rear end?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 10-04-2014, 11:27 AM   #10
buckroseau
I'm going to look at a 14 bolt out of chevy 2500 after work today. I measured my 62 this morning and face to face was approx. 65" if the axle I'm looking at tonight is within an inch it will work.
Wheel offset would probably work but that requires new rims and there not cheap. It also doesn't address the gearing issue. Axle I'm looking at tonight has 3.73's in it. This axle is $300 and cutting and welding in brackets is easy for me.
Hopefully it is narrow enough!
Old 10-04-2014, 11:41 PM   #11
Captainfab
60-66 Nut
I forgot to mention that a 14 bolt from a '73-'86 C/K30 or '87-'91 R/V3500 cab and chassis should be narrow enough
Old 10-05-2014, 09:03 AM   #12
Mathew21
Mathew21's Avatar
I was going to use C&C axle to replace mine in my 66 C20. But from what I remember when researching axle swaps the 14 bolt rear ends in 88-98? 2wd drive 3/4-1 ton trucks wms measures 65". I planned on making a trip to the Junk yard to measure one but I ended up going a different route.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 10-05-2014, 09:39 AM   #13
buckroseau
My craigslist contact for the axle got busy yesterday and couldn't meet until Monday now. I'm still excited to find out the measurement. If it's in that 65" ball park I'm good to go.
I'm assuming the yokes are different as well, so I'm hoping I can talk him into cutting the driveshaft so I can get that as well.
Old 10-07-2014, 10:16 PM   #14
buckroseau
Feel like I made some headway today on this axle deal. I stopped by a semi local salvage yard and asked if they had any c3500's on hand. Guy said he had an 8 bolt C2500, 1999 surburban. I went out and measured in the yard. Wms to Wms was approx. 65". This was without the drums, I imagine they are approx. 1/4" thick, so this would put me in that 65.5" ball park.
This was out of a 4x4, the diff was in approx. the same location, so I think it would work fine. That being said they said they would take $375 for the axle. No drums, backing plates bent and components all rusty. I think for now I'm going to keep looking. At least I know what I know it exists.
Matt
Old 10-07-2014, 11:25 PM   #15
Captainfab
60-66 Nut
I don't think I have ever paid more than $175 for a differential, usually $125. Of course that is from an individual. not a wrecking yard.
Old 10-07-2014, 11:31 PM   #16
buckroseau
I agree, just seemed to much. I will find one cheaper.
Another question. Any reason a 4wd rear axle wouldn't work vs a 2wd? Assuming they were the same length? This particular axle was 4wd.
Matt
Old 10-07-2014, 11:39 PM   #17
Captainfab
60-66 Nut
No, there is no reason to not use a differential from a 4x4. They are the same as a 2wd differential. You'll just need to weld on a set of trailing arm mounts and a panhard bar mount
Matt
Old 10-08-2014, 04:40 PM   #18
Flathead Smith
Flathead Smith's Avatar
One other option which I do not see mentioned is to find a third member from a newer Eaton ¾ (HO52) or 1 ton (HO72) and install it in your rear end. That’s what I did with my 65 C-20, of course it only took me from a 4:56 to a 4:11, but for me that was enough. I did have to cut some out of my drive shaft as the newer style Eaton was just a little longer.
Here is how I did it...you will need to scroll to the bottom.
http://67-72chevytrucks.com/vboard/s...d.php?t=534896
Flathead Smith is offline   Reply With Quote
Old 10-08-2014, 10:41 PM   #19
buckroseau
I ended buying an axle out of 1998 4wd c2500. It is the 65.625 so it should work perfect for what I'm doing. It was a 4.11 ratio, wanted to try a 3.73 but I will see how this works and if I need to change it at least I have options. This one was out of a running truck and it only cost me a $100 bucks.
Picking it up next Sunday. Once I tear into I will post up some pics of the fun.
Matt
Old 10-12-2014, 10:26 PM   #20
buckroseau
Question for the axle guru's. This 65.625 axle that supposedly exists is kicking my ass. I picked up my $100 axle out of the 98 4wd c2500. Measured it up once it once it was out and it measures 66.5". Approx 1" to wide. This hub set up looks different than that 99 suburban I looked at last week. Still bought it since I told the guy I would take it even tho it may not work.
Any options to take a 1/2" off each side? Different drums or something?
Matt
Old 10-13-2014, 12:05 AM   #21
Captainfab
60-66 Nut
I do not know of any easy way to shorten a differential 1". The 14 bolt under that other Burb had outboard drums. It is possible that switching the hubs, drums and backing plates could change the width, but I do not know for certain as I have not done that.
Old 10-13-2014, 12:08 AM   #22
buckroseau
Yeah I didn't think so. Probably end up getting a few bucks back in scrap. Oh well.
This came out of a 98 C2500. From what I can gather on the internet it is a full floater dually axel. And it didn't come out of a dually.
Old 10-13-2014, 12:11 AM   #23
66Submarine
As previously mentioned, you might also be able to use a cab and chassis dually axle, since they are narrower; I think something like 63".
If you are OK with 4.10's you can also just stick a 4.10 third member in the existing Eaton rear.
YMMV, but I recently realized I actually have 4.57's and a tach that reads slow in my C30 I drive everywhere. Have you driven the truck any at this point?
Old 10-13-2014, 12:14 AM   #24
Ozzy2013
Ozzy2013's Avatar
Im not sure but seem to remember someone making a disc conversion that made it narrower ans stop so much better.
Ozzy2013 is offline   Reply With Quote
Old 10-13-2014, 12:15 AM   #25
66Submarine
You are going to scrap a good rear end you just bought???
Also notice the first one you posted in the junkyard (that you thought was correct) has slip-on drums and the WMS on the hubs is set in farther to reduce the WMS-WMS width. Just keep looking...
