Bear Claw latches
These work real good.
Re: Bear Claw latches
![]() Join Date: Oct 2011
nice to see your post Earl.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
Do these just bolt in?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
yes after all the grinding, cutting and welding is done..
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
Hmmm...lets see, will they bolt right in....ummm...not without a little work.....
are these the standard bearclaw latches? are the stock outer handles used or are you using remotes? thanks
They are the large ones and yes all the linkage was fabed up to use the stock door handle and lock.
Seems like a lot of work to replace a set of latches that typically work fine. What's the point? Honestly, not being a jerk.
The install looks very nice BTW. I know how much work this can be and your metal finishing is very good. |
![]() Join Date: Oct 2009
I think the point is safety, with an ulterior motive of making something awesome in the process. Subtlety rocks - most folks won't even notice this when you're done. That's why I like it so much.
That is some beautiful fab work - thanks for sharing. |
I agree with jocko, if you know anything about fab. work this is really amazing. To get the latches in is one thing but to get the stock rods to operate the inner and outer handles and the lock is really hard to do. If you ask what's the point, then you really wouldn't understand.
![]() Join Date: May 2014
LOL..!! You got it..!!
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
#13 |
Does this set up stay locked when you shut the door or will the lock still pop up? That alone would make me want to do this.
#14 |
Safety? Is there a "door flies open randomly" problem with these trucks I don't know about?
