Relocating fuse block.
Shaving the firewall and looking to relocate the fuse block. I have an AAW harness. Thought about in the glove box but figured it would get in the way of vintage air setup. Any ideas appreciated.
Re: Relocating fuse block.
if your smoothing the firewall, why not just weld studs to the inside and leave it in the same spot. i did that on a 56 i had.
Senior Enthusiast
I mounted my Ron Francis fuse panel on the right side in the glovebox. I narrowed the cardboard insert so I have open access to the panel by simply opening the door. I'm running a stock economy heater and the Vintage Air under dash evaporator. I'm in my 60's with a bad back and knees, and it's a real blessing not having to twist around upside down in the doorway to deal with wiring changes:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
