Old 10-04-2014, 10:29 PM   #1
Hiluxxulih
Hiluxxulih's Avatar
jiggly rattley tailgate
Does anyone sell or make any plastic doodads to put in my tailgate hinge to tighten it up ?
Hiluxxulih is offline   Reply With Quote
Old 10-04-2014, 10:33 PM   #2
dfrank
dfrank's Avatar
Re: jiggly rattley tailgate
Rap the round trunnion in electrical tape. Cheap easy fix that works! Or just buy new trunnions.
dfrank is offline   Reply With Quote
Old 01-07-2015, 01:03 PM   #3
1966chevy
1966chevy's Avatar
I have a fix,
1958-1966 Truck Fleetside Tailgate, Ultimate hinge Trunnion (2 Piece Set) made of Stainless Steel and Delrin.
These are replacement hinge trunnion parts to upgrade your chevy fleetside truck.
These are perfect for the truck restorer!
These are Very quite while opening and closing the tailgate.
You have to reused your original Trunnion hinge plate/bracket as seen in the pictures. Just remove the bolt with lock washer, replace with these stainless steel hinge trunnions and bolt back on your truck.
I recommend power coating or chrome your Trunnion hinge plate before installing these back on it. To prevent further rusting.
See my attached link if your interested in purchasing"
http://www.ebay.com/itm/171632939274...9#ht_517wt_974
I also offer a cheaper version, Made of all Stainless steel on this listing:
http://www.ebay.com/itm/171632938635...9#ht_498wt_974 SOLD OUT
I also in the works on building 67-72 trunnion hinges.
Website is: http://tdtrunniondesign.com
My project, http://67-72chevytrucks.com/vboard/s...d.php?t=552896
66 chevy truck Fleetside LS1
67 Camaro Convertible 327
1966chevy is offline   Reply With Quote
Old 01-08-2015, 10:45 AM   #4
1774btcrew
1774btcrew's Avatar
Watching this
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 01-08-2015, 12:34 PM   #5
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Good Morning, Great idea for an aftermarket part. Except the original poster needs them for an '85. I believe the 73-87 pick-ups use two different styles.
I'd buy a set if they fit my '77. Also make the brackets as well and sell them as a set.
God bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 02-04-2015, 08:08 PM   #6
1966chevy
1966chevy's Avatar
1967-1972 and 1958-1966 Truck Fleetside Tailgate, Ultimate hinge Trunnion (6 Piece Set) made of Stainless Steel and Delrin. Now offering the complete SET!
Made in USA!
http://www.ebay.com/itm/171709176937...#ht_559wt_1094
http://www.ebay.com/itm/171709178087...#ht_413wt_1094 SOLD OUT
http://www.ebay.com/itm/171743832627...84.m1555.l2649 SOLD OUT
http://www.ebay.com/itm/171709178881...#ht_430wt_1094
Old 02-05-2015, 02:00 AM   #7
Super_Dave
Super_Dave's Avatar
Wish you had them for a 1974 Fleetside... I need some, but looks like I have to go OEM.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 02-05-2015, 03:57 PM   #8
tucsonjwt
I have had 3 squares and never noticed a lot of noise from the tailgate, unless the parts were worn and the latches on the sides were not full engaged. I would check the operation of your latches to make sure that they are tight. I don't think the trunions are usually a noise culuprit, unless they are damaged. I have seen lots of good taligate hardware at the junkyards which would be my first choice for a cheap fix. I guess if you drive on a lot of washboard roads you will hear some noise back there, but normally it should not be a problem.
tucsonjwt is offline   Reply With Quote
Old 02-05-2015, 05:47 PM   #9
kevinr1970
There is a certain amount of adjustability in the locking mechanism; the part that the latch of the tailgate "hooks" onto on the bed.
Loosen the bolts up just enough so you can move them with a small amount of force.
I got tired of messing with mine so I now have to lift the handle to shut the tailgate, but when it is shut, it is tight.
if you are more an_ _ retentive then myself you could find a "just right" spot between having to lift the handle to shut the tailgate, and just pushing it shut I would think?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 06-01-2015, 09:05 PM   #10
1966chevy
1966chevy's Avatar
Summer price break!!
Price reduced
58-66 Fleetside Tailgate Trunnion on the eBay.
47-87 Stepside Tailgate Trunnions on the eBay.
Available on Ebay right NOW!
http://www.ebay.com/itm/171718930810...84.m1555.l2649
Old 06-02-2015, 12:08 AM   #11
bmchevy1979
bmchevy1979's Avatar
In my experience it has been the links that rattle not the latches themselves but I here it more because I have run pickup tailgates on all of my blazers so I can here the noise more clearly
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 10-01-2015, 01:00 PM   #12
1966chevy
1966chevy's Avatar
I have been getting rave reviews on these items. Check out the Product reviews below!
Summer price break Continues!! Available on Ebay right NOW!
Price reduced
67-72 Fleetside Tailgate Trunnion on the eBay.
Ebay Product reviews
Fast shipping and worked perfect.
67 68 69 70 71 72 Chevy/GMC Truck Fleetside tailgate SS Trunnions Hinge SET
thanks for the trunnion hinges, fast shipping, great price, will buy from again!
58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET
great part, really helped with the rattling tailgate problem
I have been hyping you up in instagram & the 47-72 truck forum. Great product!
Quick and easy...product is awesome, Thanks
Item as described, fast shipping...Thanks!
Great seller! Super fast shipping! Amazing quality product! Thank you!
Quality Product MADE IN THE USA well packed FAST SHIPPING thanks again
Quick and easy service with high quality parts.
1954-1987 Chevrolet GMC Truck Stepside Tailgate Trunnion Hinge SET
awesome
Nice Looking product, fast shipping. Would buy again!
Nice product
Old 10-03-2015, 01:44 AM   #13
ivorton74
ivorton74's Avatar
I need to fix my 74s tailgate too...I drives me nuts hearing that thing rattle
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 10-03-2015, 03:11 AM   #14
Andybevens14
I've had some bad rattles on my truck but I couldn't imagine how annoying a tailgate could be ha I would replace all the bushings. I had taken mine off for the canopy and the rubber was toast
1986 chevy k20 4inch lift 35 inch duratracs
Andybevens14 is offline   Reply With Quote
