Old 10-05-2014, 03:29 AM   #1
DaAbominableFlip
Trailing Arm Uh Oh
So I'm driving to work the other day and this happens.
Now , what is weird is that the truck will roll in neutral and stay put when put in gear (engine off) , but will not move period if I step on the gas. Reason I put it in drive in this condition is because its about halfway in my driveway and I figured that scraping up a broken arm wouldn't be a biggy. I need a few pointers as to what is going on because everything on the rear end still looks to be straight. The frame is going through more hell than anything.
DaAbominableFlip is offline   Reply With Quote
Old 10-05-2014, 08:38 AM   #2
PGSigns
PGSigns's Avatar
Re: Trailing Arm Uh Oh
With it in that condition hard to tell what is the issue.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-05-2014, 08:43 AM   #3
71swb4x4
71swb4x4's Avatar
I am guessing that when in drive that right wheel is the one getting most of the power which is trying to push the truck away from the reared. I wouldn't try too hard you might break more parts.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-05-2014, 10:24 AM   #4
dougf
dougf's Avatar
Whoa, can we get more pics? Am I looking at this correctly and did the u-bolts holding the rear end snap?
EDIT: I see now! Wow, it just plain broke. Probably from corrosion? Yeah, I wouldnt try to drive using engine power at all, you probably have a lot of binding of the suspension parts and u-joints right now, get that thing on some jack stands!
dougf is offline   Reply With Quote
Old 10-05-2014, 04:42 PM   #5
SCOTI
SCOTI's Avatar
Don't attempt to move it. Replace the rusted/broken truck arm & inspect the other immediately.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-05-2014, 07:02 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Time to get you some Porter Built arms dude!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-07-2014, 02:21 AM   #7
andrewmp6
Looks like the trailing arm had rust in it and finally gave up.
andrewmp6 is offline   Reply With Quote
Old 10-07-2014, 08:38 AM   #8
nlped
nlped's Avatar
I had damn near the same failure, but I caught it prior to the final snap-POW!!!
Don't move it under it's own power, you risk breaking other parts...driveshaft, trans tailshaft, etc.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-10-2014, 03:56 AM   #9
DaAbominableFlip
Makes sense. I hope I didnt tear anything up. There was a huge cloud of smoke when it happened. Thinking its because the right side probably locked up. So when it comes to replacing these (never done it before) , I assume detach the rear end, get the arms hooked up and set it back on. Or is there a better way.
Old 10-10-2014, 09:12 AM   #10
SCOTI
SCOTI's Avatar
Un-bolt the shocks.
Un-bolt the bottom of the spring.
Un-hook the e-brake cables if still attached to the arms.
Un-bolt (more likely cut off) the u-bolts @ the rear end.
Remove the bolts @ the front end of the T/A.
Knock them loose.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2014, 11:15 PM   #11
michael bustamante
michael bustamante's Avatar
Daaaang! :0
1967custom
michael bustamante is offline   Reply With Quote
Old 10-25-2014, 11:55 PM   #12
SunflowersAndRust
Originally Posted by nlped View Post
i had damn near the same failure, but i caught it prior to the final snap-pow!!!
wow!
SunflowersAndRust is offline   Reply With Quote
Old 10-26-2014, 07:49 AM   #13
jjzepplin
jjzepplin's Avatar
UMM there are more rusted parts under your truck most likely. You are one lucky man this did not end your life as well as others lives. Please fully inspect your frame and front control arms as well as anything made of metal on your truck. No really Please!
And YES it is time for some Porter Built!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-26-2014, 11:10 AM   #14
502ms
502ms's Avatar
Seriously, you are blessed that this happened at home and not on the road. Sounds like you are in for a fun shopping list (trust me, it will be amazing when you complete it).
Best Regards,
Leon M.
502ms is offline   Reply With Quote
