AntiFreeze in Cab
On the passenger side of my truck on the floor mat anti-freeze has showed up twice now. Once a couple of weeks again and then again on Monday. Its not much. Where is it coming from? I can't seem to find where its dripping down from.
Nick Rodenberg 72 Cheyenne 10 V8 350/TH350 white/ochre/white/ochre, ochre/saddle interior Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Your heater core is leaking.
Yep, what he said.
its all about the +6 inches
That or the extra gallon that is under the seat is leaking.
Well.. I'll have to get that replaced. Hope it'll hold out on me for a week until I get paid again. I have the money but try to keep my checking account at a good level.
I had thought about that but didn't know.
If it does start to leak more, you can just disconnect the heater all together.
Run the hose from the one fitting to the second fitting...just with no heater inbetween. you can put it off untill it gets cold out! |
While we're getting ready for winter and all (coming sooner than I think) ......... I am gonna replace that relay or whatever it is so that my fastest fan speed work. Also what allows air to blow through the vents even when the fans and all are off?
go bucks!
that would be the air diverter(sp?) in the fan assembly box down on the floor....should be a flap that lets outside air in/and heated air from the heater core out. prolly a bad cable that lets the flap work properly.....most likely culprit. at least a place to start lookin'....
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
Set it up like this...out of the water pump, back into the intake.
