Old 10-05-2014, 09:51 AM   #1
dey59
air swap for just heater
70 gmc factory air can I swap this for just a heater or will I have holes in my fire wall when i'm done . thanks
dey59 is offline   Reply With Quote
Old 10-11-2014, 08:45 AM   #2
Baggerjohn
Baggerjohn's Avatar
Re: air swap for just heater
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
"Arrive, Raise Hell, Create Confusion, Leave".
Baggerjohn is offline   Reply With Quote
Old 10-11-2014, 09:49 AM   #3
leftybass209
leftybass209's Avatar
That's just crazy talk! Just kidding, yes I forget the company but someone makes a conversion heater box for the engine compartment portion. I'm sure someone else can chime in with more precise information.
leftybass209 is offline   Reply With Quote
Old 10-11-2014, 02:59 PM   #4
48richard
48richard's Avatar
Quick answer - yes, you will have extra holes.
This thread shows the main differences, but there will also be other holes in the firewall that you will not need, for the A/C wiring harness and the cowl air valve.
You will also have the three vents in the dash that you will not use, although there's no reason not to leave them there.
http://67-72chevytrucks.com/vboard/s...d.php?t=419390
I did it the other way round - Non A/C to A/C. None of it was too hard.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 10-11-2014, 09:19 PM   #5
71K20chevy
71K20chevy's Avatar
Firewalls are quite a bit different between a/c and non a/c trucks. Or you could get something like this http://www.speedwaymotors.com/Speedw...BTU,93550.html
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 10-11-2014, 09:30 PM   #6
jondancer
Acdelete.com but I'll tell u it's a lot of money for the product you get
jondancer is offline   Reply With Quote
Old 10-11-2014, 09:59 PM   #7
Wildcard
yes you will have extra holes and the heater and ac boxes inside and out are different, ac truck the heater core is inside the cab and ac one is outside and non heater truck hearer core is outside the cab.
believe they do make a conversion heater box that covers holes
Good Luck, Wildcard
Wildcard is offline   Reply With Quote
