Old 08-13-2003, 10:45 PM   #1
Lobo'74
Lobo'74's Avatar
Cowl Area Leaks
In a post awhile ago I mentioned I thought my kick panel air vents leaked in a heavy rain. I was wrong.
It is actually leaking from the cowl area. The water is coming in at the top of the dashboard from the windshield area. It comes down the sides just aft of the kick panel vents. Rubber seal on the windshield appears ok. Hard to tell what is under the cowl, the screws holding it and the rubber cowl seal are both rusted in and painted over.
*Anyone know the size of those 'lil things so I can have them on hand after I strip the heads and have to drill/easy out them out?
*Anyone had this leak? Any way to fix it easily (now come on, quit laughin' so hard)?
Thanks for any help/ideas.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 08-13-2003, 10:59 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
<----not laughing. Every truck i have had would soak the passenger's feet...and the GMC pees on my feet too.
Old 08-13-2003, 11:04 PM   #3
krazy_texan
krazy_texan's Avatar
ditto to that longhorn
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 08-13-2003, 11:34 PM   #4
Longhorn Man
Yeah, but it don't rain in Texas.
Old 08-14-2003, 12:06 AM   #5
beautimus
beautimus's Avatar
something you might check(if you haven't already) before you pull the cowl cover off,
up on the firewall , right in the groove that the plastic wire gutter sets in, is a body seam. it has little if any seam sealer in it and just a few spot welds holding it together.
i have seen a few of these with a broke spot weld or two and the seam is gapped open, due to rust out. its kinda hard to see with the hood on, but wouldn't it be great if that were the leak and you could fix it without pulling the cover.
hope that helps. tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
