Old 10-05-2014, 03:44 PM   #1
dhamilton62
dhamilton62's Avatar
question about T5 swap
Just wondering for any of you that have done the T5 swap, what Universal joint did you use to fit the out shaft yoke from the T5 to the stock driveshaft? Thanks!!
dhamilton62 is offline   Reply With Quote
Old 10-05-2014, 06:32 PM   #2
dhamilton62
Re: question about T5 swap
nevermind, found a combination u joint that will work. Thanks!!
Old 10-06-2014, 07:54 AM   #3
brokenspoke
brokenspoke's Avatar
I had to shorten the driveshaft on mine.....I took the original drive shaft and the new yoke and measurements to a drive shaft business
brokenspoke is offline   Reply With Quote
Old 10-06-2014, 10:37 AM   #4
NEWFISHER
NEWFISHER's Avatar
Just did the swap on my 46 burb that's running a 55 car 3 speed. The T5 has the same 27 spline output and my old shaft slid in, but had to be shortened 3". I still have the S10 yoke/driveshaft that I grabbed thinking I was going to have to use it and get a conversion joint for the rear. Check yours, you might have the correct spline?
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
