Old 10-05-2014, 08:46 PM   #1
Blue666(2)
Upper Cowl Rust
I have finally located the source for the water leak behind the dashboard. I checked from below and it does not appear to extend any higher. I removed the vent cowl and saw that the firewall is seperated cowl panels.
Has any one else tackled this problem. How much firewall do I remove so I can clean and reinstall? Will the windshield need to come out?
Also, can anyone recommend a better spot weld cutter? I drilled about 20 spot welds and these were toast.
Blue666(2) is offline   Reply With Quote
Old 10-06-2014, 08:49 AM   #2
Improbcat
Improbcat's Avatar
Re: Upper Cowl Rust
You can flip the heads on those cutters and get more cuts out of them.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 10-08-2014, 08:07 PM   #3
Blue666(2)
Re: Upper Cowl Rust
Thanks, I used all four sides on the cutters. Wondering if the other style or another brand are any better? These were Northern Tool brand.
