Old 10-05-2014, 09:44 PM   #1
Russ.W.
Russ.W.'s Avatar
Question Part ID - small plate bolted to chassis
Can anyone tell me what this is used for?
The original was pretty much ruined, but I had my body guy make up a new one when he repaired the chassis.
It's a piece that sits between the lower rail of the chassis, and one of the rear cross braces. I removed it as I needed to repair the frame under that section, but have no idea what it's for. I don't recall removing anything from it during the tear-down.
Old 10-06-2014, 01:10 AM   #2
Wizo
Wizo's Avatar
Re: Part ID - small plate bolted to chassis
Russ, Ron here. In your photo there is a cross brace missing but basically its the hard mount on the frame for your pan hard bar. Here are some pix of mine.
first one,left side of truck looking rear wards.
second one,same view but from more overhead.
third one,from left side looking to right side.
forth one, looking straight up.
i do hope you still have that bracket?
fifth one, that thing that lets all the smoke out of my tires.
hope this helps. Have a good day.
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 10-06-2014, 03:30 AM   #3
Russ.W.
Russ.W.'s Avatar
G'day Ron. Thanks for the info, I removed the panhard bar so long ago I didn't remember that's what it was for
Yes I did keep the bracket. Simply had to remove it so I could repair this underneath it
