![]() Join Date: Oct 2013
Undercoating removal
So whats the best way to remove undercoating from a frame the sandblast guy says that doesn't work just gums up.Thanks Oz
Re: Undercoating removal
I used a heat gun and a scraper. Lots of work.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
ZEP Orange Gel Degreaser removed 3 year old asphalt sealer from my basement floor with ease....I wonder if it would have any effect?
I will have to try some thanks for the replys guys!Ive been scraping and it is time consuming.
I had same problem, used zip strip. worked.
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
2WD Jimmy
![]() Join Date: Mar 2005
Eastwood has a special spray on product for that. I have found that their products work well. http://www.eastwood.com/under-gone-u...17-oz-net.html
I used a small proprane torch and a putty knife... heat it up a little and scraped it right off.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
![]() Join Date: Apr 2007
I never did it myself and maybe someone who did will chime in on this but I think I remember reading posts on here that guys used oven cleaner. Not sure though.
#10 | |
#11 | |
Still Learning
It's slow but it works better than anything else I tried. You can also use a wire wheel on your angle grinder but it is messy and time consuming. |
![]() Join Date: Nov 2013
I scraped the whole underneath of my Challenger-took 20ish hours. I did not want the mess of a chemical, and up here in the great white north we don't have the selection you 'southerners' do LOL. I used a scraper (hard putty knife) and a heat gun, but mostly the scraper. Hard to reach areas I used a wire wheel on an old drill. It heated the undercoat up from friction and worked real well, but time consuming. I then had the underneath sandblasted. I also used wd40 to soften the thick hard to reach areas. good luck
#13 |
Thank you everyone !Been using a torch and wire wheels on 4 and a half inch grinder.Slow but steady.
