1 ton/dually guys need info!
I'm considering trading my 98 Z71 for an 89 CC dually 454/T400. I've never had a one ton truck so are there any one ton specific issues to look out for?
I've had my 78 for many years so I'm well aware of the normal squarebody issues, and places they rust. Thanks for any advice you can give. An before anyone asks, no I dont really have any specific need for a dually. I would like the crew cab over my ext cab since I have 3 kids but its not really a necessity. Yes I will "ruin" the dually with a mild lowering and if I ever can afford them a set of semi rims. I will then proceed to drive the tires off it. Its just something I've wanted for a while and happened to see this guy offering to trade on criagslist. Paul
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
Re: 1 ton/dually guys need info!
Only issues really are the heaviness of the parts! When you do rear brakes you'll need to pack a lunch, but the rest will be strangely familiar. Don't listen to anyone that offers opinions of what you should do to your truck unless they are buying! Good luck!
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
Might want to consider changing to an overdrive transmission for better fuel mileage.
Don't think this is a fuel mileage play, is it?
Not really worried about mileage, my 98 is lifted on 305/70 mud tires so it's no fuel sipper itself. I know this one will be rough with no overdrive, with the tbi would it get double digits?
Rear brakes are a PITA vs 1/2 ton trucks. Not really different, just more difficult.
OD would be a very good idea. Mine was in the 8mpg range w/o it using the same TBI-454-th400 combo w/235-85-16's (31.5") tires. Very poor turning radius @ stock height that will only get worse when lowered. There's a bunch-o-weight @ the 4 corners that will only be amplified w/large semi wheels + required adapters. It's fairly easy to get any corner shop or out of town joint to service dually wheels w/rated tires. Getting semi wheels w/non-rated tires serviced is prob going to be an issue @ many reputable shops so something to keep in mind when venturing any distance. As said on here many times before, lowering doesn't impact towing/cargo capacity if you plan accordingly & spend money where necessary. The semi wheels w/LT tires will limit the capacity. That simply requires honoring those limitations....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-06-2014 at 06:07 PM. |
I recently put semi wheels on my 89 dually and it rides way nicer . and the rims with the tires are much lighter . Since you are gonna use it for fun , towing shouldn't be an issue . With 4 tires in the back you should still have about 8000lb capacity. here is what mines looks like its a work in progress. also with the larger rims and tires I think the rearend gear ratio should be way under 4:11 which does lower rpm.
#8 | |
What was the weight of 1 wheel/tire + adapter?
I did not weigh the rims and tires , but the adapters are heavy it will probably be a little more than a regular wheel and tire setup , but I have no regrets if I were to lower it I would only lower the back a little
tires are 305/35/24 . I use reg tires I had the wheels cut to fit them
I also just had the thought that my 78 is getting a nv3500 soon. That would free up my 700R4 an I could put it in this truck if I get it. I know it wouldn't be ideal if I was using the truck to its capacity but I think for my use it would work ok. It's not a stock transmission either so I believe I could make it live behind a 454....
#12 | |
| Bookmarks |
