Old 10-06-2014, 01:56 PM   #1
JAG66
Drop shocks for lowered 87?
I have 2-1/2" drop spindles on my 87 SWB. Can I run stock shocks and be ok or do I need to find a shorter shock due to less travel distance?
If so, recommend a good drop shock? Is there a shock at Advance Auto/CARQUEST, etc. made for another vehicle that will substitute?
JAG66 is offline   Reply With Quote
Old 10-06-2014, 02:16 PM   #2
03glide
Sell it before it's finished
03glide's Avatar
Re: Drop shocks for lowered 87?
I just did a 4/6 drop on my 81. I used Mcgaughy's lowered shocks. I ordered mine from Jegs for 39.00 each and free shipping.
03glide is offline   Reply With Quote
Old 10-06-2014, 02:37 PM   #3
tinydb84
tinydb84's Avatar
If you have drop spindles only then you don't need drop shocks. If you intend on going with shorter springs later then order drop shocks.
David
Instagram: myfabguy
Old 10-06-2014, 05:18 PM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
a stock length shock is the correct shock for this application. I like how the Monroe sesna-tracks perform on a lowered truck for a more "stock" feeling ride, and QA1 adjustables if youre into handling.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-08-2014, 10:58 PM   #5
Tilt
I have 3" spindles and 1 coil cut off the stock springs and just put on a set of the Monroe Sensa-Trac shocks (37049) and they work great.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
