new window rubber and window is tough to move
Help!
I just installed a gmcpauls kit this weekend. It's a great kit....and I highly recommend it if you are going to redo your seals. But..my when rolling my windows up and down, it is extremely tough. I have adjusted the front and the rear window track to what I believe is the proper position. Am I right to assume that it will get easier the more I use the window....or is there a trick I can do to make it operate more smoothly?
1970 Chevy C10 Fleetside SWB 1998 Dodge Viper RT10 1999 Harley Road King 2006 Ford F250 CC SWB 2008 GMC Yukon Denali My Build Thread |
Re: new window rubber and window is tough to move
I have the same problem, same kit, same vendor . I can't figure it out either
thats common with just about all the kits it should loosen after awhile especially if ti sits in the sun some.
Loosen the bolts that hold the bottom of the vent window, roll up and down a few times then retighten.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
I actually tried that because I had my wing window assembly out to redo it. I also tried moving a combination of the wing window and rear channel. It made it a little easier. But after doing some reading on other forums, it seems like everybody says to give it some time...
