Old 10-06-2014, 05:33 PM   #1
sbc10guy
sbc10guy's Avatar
where do you guys get your engine mounts?
Im swapping in a big block in my 69 c10 and i was going to order some mounts from lmc but there has to be something cheaper than 160 bucks. Where do you guys get your mounts from. i heard i can use small block ones and drill them out? is that correct? If so im guessing they are cheaper. I would try it with mine but they are in bad shape. Thanks in advance.
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 10-06-2014, 06:19 PM   #2
cdowns
cdowns's Avatar
Re: where do you guys get your engine mounts?
I've always gone to my local NAPA to get commonly available parts like that
Old 10-06-2014, 08:51 PM   #3
sbc10guy
sbc10guy's Avatar
Ok i think thats the only parts store i did not check all the others say they cannot get them. Not sure why but they are hard to find. I will call napa tomorrow to check.
1969 shortbed c/10
1998 GMC sierra
Old 10-07-2014, 06:11 PM   #4
sbc10guy
sbc10guy's Avatar
I have called all the auto parts stores in my area and none can get them. They carry small block mounts that are very cheap. Should i just get those and modify them to work with my big block frame stands or am i better off paying 80 bucks apiece for the big block ones from lmc?
1969 shortbed c/10
1998 GMC sierra
Old 10-07-2014, 06:17 PM   #5
69Rumbler
69Rumbler's Avatar
dont be cheaper when it comes to engine mounts lol
1969 C20 CUSTOM "RUMBLEr"
69Rumbler is offline   Reply With Quote
Old 10-07-2014, 07:25 PM   #6
bigmac73
bigmac73's Avatar
check out summit racing, I think that prothane makes them
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-08-2014, 09:41 PM   #7
sbc10guy
sbc10guy's Avatar
Well i checked out prothane and the mounts looked different. They probably were fine, i think thats what i ordered when i did my chevelle. With no luck anywhere else i decided to just go with lmc and get the right mounts. Thanks.
1969 shortbed c/10
1998 GMC sierra
