trans leak
i installed a TH 400 from summit and it leaks from were the shifter bracket bolts to the trans. how do i fix this?
Re: trans leak
Change out seal behind bolt and bracket, it's funny it leaks as Summit should of put a new one in, phone them maybe they will pay for transmission shop to change it out for you, but from the looks of your picture your vehicle is a bit immobile for now.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
Re: trans leak
thanks for the reply,is this something i can do or does a trans.shop have to.I live on a island and the nearest trans.shop is a 2.5 hr boat ride the truck does run and yard drives.
Re: trans leak
Is there one even in there?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
