Old 10-06-2014, 09:12 PM   #1
Hydra
Hydra's Avatar
Left turn signal mystery
When I got my truck the wires to socket were cut at the very base so I got a new socket and I have it wired up but when I turn on the park lights or the turn signal it won't turn on? It's getting power at the socket and I've put in 2 different bulbs and it still won't come on.when I hit the lever for the left turn the dash indicator is just a steady green but won't flash if that helps.also the blue wire is acting as a ground when I have the park lights on and I haven't tried it with the signals,is that of any importance?
Hydra is offline   Reply With Quote
Old 10-06-2014, 10:33 PM   #2
VonDog
VonDog's Avatar
Re: Left turn signal mystery
I'm no guru but the solid turn signal indicator sounds like a bad flasher unit - also, a good solid ground makes the world of difference. A bad ground can cause all kinds of really weird issues. I had to hard wire a solid ground from the bucket (tail light housing) to the frame to fix my "ghost" issues.
VonDog is offline   Reply With Quote
Old 10-07-2014, 11:58 AM   #3
jtrichard
if it has a med./light duty flasher then if one lite is not working then it wont flash that is there to tell you that a light is not working... does it flash on the right side? with the wires unhooked from the socket take a test light and see if you have both park and turn power on the wires then you can narrow it down
jtrichard is offline   Reply With Quote
Old 10-07-2014, 04:29 PM   #4
Hydra
Hydra's Avatar
I'm getting power at the socket when turn signals are on and also getting power when park lights are on.is there a reason why the bulb still isn't coming on?the power is constant when the turn signal is on if it's any importance.also the right signal works fine.
Old 10-08-2014, 02:56 AM   #5
jtrichard
the light can and socket have to be grounded after looking at your pics again i see that the can is just laying on the core support get it grounded and see what that does.... as i said before if you have a light duty flasher then when only one bulb is on/working then it WONT flash it will just stay on... your meter is not enough load to make it think there is a bulb in play
Old 10-08-2014, 12:26 PM   #6
Hydra
Hydra's Avatar
Thanks jtrichard and vondog.
You were right about the canister,as soon as I installed it it came on flashed as normal,thanks again guys.
