Old 10-07-2014, 03:19 PM   #1
EVILSTANK
voltage regulator problem- opinions?
Having an issue with my voltage regulator. Sometimes my truck won't start so I'll have to pop the hood and hit on my voltage regulator a few times then it starts right up. Replaced the regulator with a new, same issue. Opinions? Thanks.
EVILSTANK is offline   Reply With Quote
Old 10-07-2014, 04:48 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: voltage regulator problem- opinions?
Sounds like a wiring problem. Likely have a wire with a break internal but the outer covering is not broken. Had this happen with my '65 C10. Wire looked fine but had an internal break.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-07-2014, 05:18 PM   #3
EVILSTANK
Thanks the reply. I will check all the wiring there for breaks.
Old 10-07-2014, 06:44 PM   #4
KJSR
KJSR's Avatar
Stop hitting the regulator and start moving the wires when the issues occur.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
