Old 10-07-2014, 06:42 PM   #1
mygirlz55
Drivers side door question
Does this section of the drivers side door have anything "stock" that belongs here?
It looks to me that somewhere down the road a mirror might have been here and got broken off??
Also how should I go about repairing these areas? There was a poor attempt at brazing and the metal is "cracking" outward from the patched areas.
Should I just cut out the sections and weld in new sheet metal?
mygirlz55 is offline   Reply With Quote
Old 10-07-2014, 08:48 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Drivers side door question
Probably a mirror was mounted there. Id find a used door that has a bad bottom and a good top and replace that section. cut out past the brass.
dwcsr is offline   Reply With Quote
Old 10-07-2014, 09:10 PM   #3
mygirlz55
Well after a bit of sanding, found some bondo and I uncovered this... looks like I've got some repairs to do.
Old 10-08-2014, 12:18 PM   #4
_Ogre
_Ogre's Avatar
the 3 holes up front in the triangle pattern are for the stock mirror, you should have a brace and captured nuts inside the door
west coast mirrors were common on these trucks, any truck in the 70s and 80s
the truck with biggest mirror with the most chrome was usually the choice, though the cheapest from kmart was installed
truk had evidence of 3 different mirror mounting brackets similar to what you have
shop air compressor timer
Old 10-08-2014, 06:46 PM   #5
mr48chev
mr48chev's Avatar
The doors in my 71 GMC have so many ripped out holes where mirrors were bolted on and my uncle hit something and knocked them off that I lost count. I think he drilled 54 separate holes in the whole truck to mount different things though.
I'm with Dave on that I think I'd find an other wise damaged or rusted door that had that section in good shape and cut the section out and put in a patch or cut the section out and make a patch. I've battled brass that someone else put in before I got there and it can be a pain.
My ongoing truck projects:
Old 10-08-2014, 07:17 PM   #6
OrrieG
OrrieG's Avatar
Ogre is correct, I welded up about 10 holes on each door from previous west coast type mirrors, including one ones I drilled for the mirrors in my avatar. The bed had about the same from various hooks and hold downs.
OrrieG is offline   Reply With Quote
Old 10-08-2014, 08:45 PM   #7
mygirlz55
Definitely one of those old mirrors. I found some more bondo at the top.
Probably going to get a lower door patch panel and some sheet metal for the mirror mount holes. Gonna keep the stock mirror location.
They had bolts with the heads ground off and bondo over those in the stock mirror location.
Can't we get some kind of legislation in place for the misuse of bond and body filler
Old 10-09-2014, 04:35 PM   #8
_Ogre
_Ogre's Avatar
too late for our trucks and why bother with the new crap out there
i feel for the poor kids trying to hotrod a 2014 impala 50 years from now
Old 10-10-2014, 09:10 PM   #9
mygirlz55
Too funny. Ive often thought about what my grandkids will thing is 'cool'.
Dont think there will be anything vintage for them.
