Old 10-07-2014, 09:09 PM   #1
Slug96
Slug96's Avatar
Trim
The trim that goes along the side of the bed has fallen off.
I bought new trim at the beginning of the year when I got my truck repainted. I did not realize that the paint shop used double-sided tape to stick the trim together. Now, the trim will not stick to the truck. I put new tape and it did not last long. I took it to a local body shop to see if they could fix it, but they said there was nothing they could do. They could of drill holes and put screws in, but it would make the truck loose the clean look to it. What other options do I have?
Thanks,
David Carballido-Jeans
Flagstaff, AZ
David Jeans
1976 C20 Silverado Camper Special
Slug96 is offline   Reply With Quote
Old 10-07-2014, 09:15 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Trim
remove the two sided tape. make sure that no wax or anything else is on the trim and the door then replace the sticky tape and re install on a nice warm day or in a heated garage let the truck sit that way for several hours before putting the truck in a varying temperature
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-08-2014, 07:46 AM   #3
Keith Seymore
Keith Seymore's Avatar
Re: Trim
Thanks,
Flagstaff, AZ
The stamped aluminum side trim on your '76? That should have clips and mechanical attachments, not tape. It really should go back on that way.
However, if you decide to use sticky tape Rusty's procedure is correct with two caveats:
1) use a solvent like denatured alcohol or paint surface prep to wipe the side and let it dry. It is very important that the surface is clean. Don't remove the backing from the tape until right before you are ready to install.
2) Press HARD afterwards, along the whole length. In the assembly plant adhesive moldings are rolled over with a mechanical roller after installation at it presses hard enough to deflect the sheet metal (not permanently). You've got to really "wet it out" if you want it to stick for a long time. I used the wife's roller from the kitchen (don't tell her I did that, please).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
