Old 10-07-2014, 09:15 PM   #1
MichiganJames
s10 retrofit
how much stuff can be retrofitted on a s10 with a 4.3? I am thinking for now i will use the 4.3, frame, and everything else I can.
What else can I use? Gas tank? brake and gas pedal? cruise control? steering column? all electrical? heating and cooling? I dont see why the possibilities arent endless. thanks
1954 Chevy 3100 -- In the work to be layed out
MichiganJames is offline   Reply With Quote
Old 10-08-2014, 12:30 AM   #2
iowaboynca
iowaboynca's Avatar
Re: s10 retrofit
See the S10 How-To up in the stickies written by Skymangs.
iowaboynca is offline   Reply With Quote
Old 10-08-2014, 04:52 AM   #3
msaintg
msaintg's Avatar
Re: s10 retrofit
I used almost everything from an S10 Blazer. Using a Blazer platform was a lot more work than using an S10, but I got it done. The only thing I did not keep was the anti-lock brake unit and the airbags. I even used all of the gauge cluster, charcoal canister, catalytic converter, and computer port so that the fuel injection would perform the same. I could pass emissions if I ever need to.
A lot of guys talk about using an S10 frame conversion, but I think that is short sighted. I can take my truck to any mechanic and I don't have to remember what the rotors were from or what hose I used .... it is ALL from the same vehicle.
msaintg is offline   Reply With Quote
Old 10-08-2014, 10:58 AM   #4
oossuuu754
oossuuu754's Avatar
Re: s10 retrofit
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline   Reply With Quote
