10-07-2014, 11:01 PM | #1 |
need camshaft help!
Ok i know there are many threads on this subject and i apoligize. But ive never went this deep into an engine and wanted to be clear.i have a '72 gmc c2500 with a stock 350 and quadrajet 4 bbl. It is my daily driver and i want to change the camshaft and give it alil more thump and go but dont want to over do it.gas milage would be good but lets be honest its a brick so nothing great is expected. What is a good came for it? What duration, lift,flat tappet,hydralic roller? Also what else would i need to change besides bearings if i want a different cam?
10-08-2014, 08:18 AM | #2 |
Re: need camshaft help!
Here are the spec's on mine, Comp Cams HE 268. It was a kit that included springs, retainer, lifters, and cam. Here is how it sounds.
https://www.youtube.com/watch?v=Ge-F...ature=youtu.be
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
10-08-2014, 08:26 AM | #3 |
10-08-2014, 10:09 AM | #4 |
the 268 cam posted above is probably the best cam to use
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
10-08-2014, 10:47 AM | #5 |
is that a hydraulic flat tappet cam? and where did you purchase it from? im looking it up on comp website and the only high energy is listed as a marine cam? is that the same one?
10-08-2014, 12:56 PM | #6 |
I put the part number into Summit's web site and the cam came right up. I would call Summit or Jeg's and tell them what you are looking for and they can help out. Mine is a BB so the number will be different for your application. Don't use regular oil with an additive, use Comp Cams break in oil for the 20 minute break in period once installed.
http://www.summitracing.com/parts/cc...commendedparts
