Old 10-08-2014, 10:38 AM   #1
Spblack
Spblack's Avatar
cab mounting
This may sound like a dumb question, but whats the order these go on for my truck? I cant find anything on the web.
Thanks.
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 10-08-2014, 11:50 AM   #2
_Ogre
_Ogre's Avatar
Re: cab mounting
http://67-72chevytrucks.com/vboard/s...d.php?t=439277
the shims and thin rubber are the front mounts, truk has the rubber only
when you mount the front fenders add the shims if needed to raise the front of the cab
rear mounts: big block sits on the frame, set cab on rubber and drop in bolt.
from the bottom install metal sleeve, rubber spacer, big washer and snug it up on the nut
very similar to the core support mount
shop air compressor timer
Old 10-08-2014, 03:05 PM   #3
Rude Dude
Rude Dude's Avatar
Re: cab mounting
I was looking at assembly manual: The larger bolt at rear goes up from bottom with lock washer (not needed if self locking nut) than large flat washer(fender style), large rubber cushion biscuit with sleeve than pass through the body bracket (frame), then shows another large rubber cushion washer and end of bolt protruding inside cab with nut. The flat U Shape washer and rubber are for front.
Rude Dude is offline   Reply With Quote
Old 10-09-2014, 09:52 AM   #4
Spblack
Spblack's Avatar
Re: cab mounting
Look right? Large bolt goes up front.
My builds:
Old 10-09-2014, 11:12 AM   #5
Rude Dude
Rude Dude's Avatar
Re: cab mounting
Looks right according to manual
Old 10-09-2014, 01:40 PM   #6
OrrieG
OrrieG's Avatar
Re: cab mounting
Looks good, front mounts are relatively rigid to keep every thing lined up, back is rubber to give some cushion....
OrrieG is offline   Reply With Quote
Old 10-09-2014, 04:17 PM   #7
_Ogre
_Ogre's Avatar
Re: cab mounting
ok ok ok... i had the bolt upside down
so does truk
