10-08-2014, 01:51 PM | #1 |
bad quality aftermarket fuel rails, what can i do ?
Hy all
finally i got my new set of fuel rails for doing a return fuel setup. After i have checked the rails i found out that there are some small blades inside of the center whole... For details pls check the pics... I am from Germany so its not easy to send it back, therefore i hope u know any solution for smoothing the rail at the inside of the center whole.. Thanks a lot Achim |
10-08-2014, 06:40 PM | #2 |
Truck and auto performance nut
Re: bad quality aftermarket fuel rails, what can i do ?
not sure what you are seeing. can you clean it out with a wire brush or something?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-08-2014, 08:57 PM | #3 |
You can have a machine shop chase the treads and clean the burrs and clean the sides
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-09-2014, 03:07 AM | #4 |
meowMEOWmeowMEOW
Ya it just looks like some burs on the machining in the aluminum.
You can have a machine shop or mechanic shop chase the thread, or get the correct size tap-and-die (thread chaser) and do it yourself. Shouldn't be a big deal.
10-09-2014, 08:21 AM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
also an Emory cloth would help for delicate deburring also.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
