Old 10-08-2014, 02:35 PM   #1
rusted72'
rusted72''s Avatar
lower steering column question
Gents,
I am trying to figure out what I am missing from my lower column or why it is loose. The lower column shaft moves easily up/down and it moves in and out about 1/2" causing the steering wheel to move forward and back. I can see a bearing in there but nothing is holding it...am I missing something??? will a new bearing solve all?
any help would be appreciated.
thanks in advance.Name:  imagejpeg_0.jpg
rusted72' is offline   Reply With Quote
Old 10-08-2014, 02:40 PM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: lower steering column question
Tou need a low column beering at least and possobly the spring that pushes it you in place.
I'm sure others will chime in with more info !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 10-08-2014, 02:44 PM   #3
CUSTOM/10
CUSTOM/10's Avatar
Items 20, 21, 22, 23 I'm thinking !
Gary
72 SWB 4x4
My 72 SWB Build
Old 10-08-2014, 03:33 PM   #4
rusted72'
rusted72''s Avatar
Sounds easy enough.
Thank you Gary, I will give it a shot this weekend.
Old 10-08-2014, 03:48 PM   #5
FirstOwner69
FirstOwner69's Avatar
Th picture Hamjet just posted of his engine bay in post 108 of this thread http://67-72chevytrucks.com/vboard/s...=549556&page=5 shows what your column should look like.
FirstOwner69 is offline   Reply With Quote
Old 10-08-2014, 03:55 PM   #6
john
member #16
john's Avatar
Can't tell from pic, but do you have the washer and spring? Post#6
http://67-72chevytrucks.com/vboard/s...d.php?t=591419
john is offline   Reply With Quote
Old 10-08-2014, 04:07 PM   #7
JointTech
JointTech's Avatar
number 20 is the whole kit. you dont need the others mentioned if you get the kit.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 10-08-2014, 06:52 PM   #8
rusted72'
rusted72''s Avatar
firstowner69-thanks
john-I have a spring not sure about the washer, I will check when I get home.
jointech-good idea I will get the kit and get it all over with. HAHA
thanks a million y'all.
this site is great!!-glad to be a part of it.
