Old 08-14-2003, 03:39 AM   #1
chevy69er
1/2 ton and 3/4 ton mix
Just wanted to know if anyone knows if it is possible to take 1/2 ton a-arms and use 3/4 ton spindle and/or rotors?Any help would be appreciated.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Old 08-14-2003, 09:05 AM   #2
crazy longhorn
Fabricate till you "puke"
You can swap the balljoints on the TOP arms, & fit either a 1/2 or 3/4 spindle......the lower arms have a different hole size for the balljoint & need to be changed to fit the balljoint. Are you swapping 3/4 ton parts under your 1/2 ton?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-14-2003, 03:42 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It may be easier to swap the whole front cross member out...but only if the engine is not in it at the time of swapping.
Old 08-15-2003, 03:31 AM   #4
chevy69er
What I am trying to do is lift the truck.I have only found one company that makes lifted a-arms and they are only for the 73-87 1/2 tons.I want to put them on my 3/4 ton.If i cant make the ball joints work with the 3/4 ton spindles is there any way i can make 8 lug rotors work with 1/2 ton spindles...may some wheel bearings from something else.If i cant get this to work i guess im just gonna have to shell out big bucks and have something custom fabricated.Thanks for the info guys.
