Old 10-09-2014, 02:07 PM   #1
Savidio44
Savidio44's Avatar
Paint under cab/bed/fenders
1969 C-10 Long Fleet. Have had cab/bed/fenders et al bead blasted. What do you guys recommend for the underside of the vehicle to look good as well as provide decent rust protection. Truck will be an infrequent driver. Thanks in advance for your help.
Savidio44 is offline   Reply With Quote
Old 10-09-2014, 02:58 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Paint under cab/bed/fenders
This is what I use....
Amazon.com: 3M 08864 Body Schutz Rubberized... Amazon.com: 3M 08864 Body Schutz Rubberized...
You need the applicator gun too. It really isn't messy and looks really nice when it dries.
Here are a couple of pictures of the underside of my '36 Ford with it applied.
LockDoc
Leon
Old 10-09-2014, 03:52 PM   #3
farmallboy15
I used summit racing epoxy chassis paint. Smooth matte finish. Seems pretty heavy duty and is reasonably priced. Not Berliner like, like above..
farmallboy15 is offline   Reply With Quote
Old 10-09-2014, 07:31 PM   #4
LockDoc
LockDoc's Avatar
What I posted above is not bedliner, it is undercoating....
LockDoc
Leon
Old 10-09-2014, 07:50 PM   #5
farmallboy15
LockDoc I didn't mean yours was bedliner, I meant like bedliner (textured).
Old 10-09-2014, 08:21 PM   #6
Wizo
Wizo's Avatar
Por-15
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 10-09-2014, 08:50 PM   #7
hugger6933
I am doing three trucks kinda at one time and I have been debating the same thing on these. I am thinking about three different things one for each different truck. One I think will be bc/cc just as on the top side. Now on the inside of the fenders and underside of the hood all of the things like that I think they all should be either black[semi flat ] or body color. If your wanting a little bit of a later model feel paint it all body color underneath like a cars under structure[under the hood]. POR 15 or under coat on the underside is a good option. 3M makes a product called rocker guard that is a textured product and you can vary the texture yourself from very little to a bunch and it can be top coated, I think that would look great underneath one. That has been one of my thoughts for one of my builds. One of my trucks has such a nice steel floor [one of the nicest Ive seen] I just want to paint and clear it will have to be just as pretty on bottom as it is on top. After all isn't that why they sold me the rotissere that is just sitting out by that old truck? Jim
hugger6933 is offline   Reply With Quote
Old 10-30-2015, 08:49 AM   #8
73737373
I use rustoleum rattle can semi-gloss black on the fender wells. Lasts forever, if you prep correctly, and you're just $4 away from another can of it should you need to do some touch-up later on.
73737373 is offline   Reply With Quote
Old 10-30-2015, 10:26 AM   #9
67chevemall
67chevemall's Avatar
30 cans of Flat Black Tremclad. Blast every inch of er
$280
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-30-2015, 01:41 PM   #10
bs46488
The PO of my Nova project put down lizardskin on everything and I hate it.
I've been removing most of what left (that's hasn't failed and flaked off)
I'll use an epoxy semi gloss black
bs46488 is offline   Reply With Quote
Old 10-30-2015, 06:38 PM   #11
jocko
jocko's Avatar
am curious why you hate lizard skin - I don't have it, was considering it for interior sound deadening under the carpet padding. It doesn't seem like an appropriate coating for exterior use though, so that's why I wanted to ask.
Old 10-30-2015, 07:12 PM   #12
bs46488
Just a couple of random reasons put together:
It is an ugly finish. He put it on the floor of the interior, the under carriage, firewall, and cowl. Between working and sitting it collects dust and since the finish is rough, you can't wipe any of it clean.
I'm trying to install some brackets for bucket seats and all of the product needs to be removed for welding. Its difficult to remove.
The idea of having to buy special airgun kit to spray it is a distractor for me also.
Old 10-30-2015, 09:48 PM   #13
olebluegmc
I've heard awesome things about raptor liner. It's like a rhino liner material. It's like $100 with a gun included. That's what I plan on doing my underside and inside with when I finish my cab
olebluegmc is offline   Reply With Quote
Old 11-01-2015, 11:30 PM   #14
jomatt20
jomatt20's Avatar
My interior floor pan, under cab, inner bed sides and under bed floor have all been 2k epoxy primed then 2k raptor liner. Love it, They have a tintable version if you want it to match you paint as well if you have a color picked out
jomatt20 is offline   Reply With Quote
Old 11-01-2015, 11:54 PM   #15
Metaldoc
Metaldoc's Avatar
Black stone guard with satin clear on top. Sealed it up and washable.
Metaldoc is offline   Reply With Quote
Old 11-02-2015, 12:34 AM   #16
CG
BlahBlahBlah
I think Lizard Skin is more of an interior product. Ive used it many times and have had zero problems with it. And I didn't use their sprayer, I just brushed it on. Its just like any other product, follow directions for preparation and installation.
Also because it is thick and tough you need to plan ahead before using it and be sure you aren't going to need to modify the metal you are coating. It should be the last thing you lay down before carpeting.
