Old 10-09-2014, 04:20 PM   #1
57larry
Vent Window Installation Help Needed
Did a search on here and on you tube and read through the material but am still lost on how to install the vent window. Does anyone have detailed instructions or a link to a video. Any help would be greatly appreciated!
57larry is offline   Reply With Quote
Old 10-09-2014, 05:52 PM   #2
john
member #16
john's Avatar
Re: Vent Window Installation Help Needed
Here's a thread on replacing a window regulator which includes the vent window.
http://67-72chevytrucks.com/vboard/s...d.php?t=157539
john is offline   Reply With Quote
Old 10-09-2014, 06:17 PM   #3
Aussie Ol' Blue
Aussie Ol' Blue's Avatar
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
This might be helpful.
https://www.youtube.com/watch?v=WiZOiHmcb_w
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY!
IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE!
Aussie Ol' Blue is offline   Reply With Quote
Old 10-09-2014, 07:46 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
There are a couple of different thoughts on this but here is how I assemble mine.
Make sure you have the new felt window channel in the wing window. But do not install the felt channel around the top and down inside the rear of the door yet.
Insert the rear glass guide/channel into the door but don’t bolt it in place yet.
Install the door latch remote and window riser mechanisms if they have been removed.. (make sure the roller is in the track on the inside of the door)
Install the window. (you have to slide it toward the front to get it started into the roller guides) After you have the window installed roll it down, and slide it back toward the door latch. (make sure it doesn’t slide out of the track)
Insert the wing window lower bracket into the window opening from the inside of the door, about where the window and wing window meet. After it is inside the door rotate the wing window to it’s correct orientation and slide it down into place.
Put the three (I think) small flat head screws through the angled part of the door frame and into the wing window, then put the two ¼” machine screws through the bottom holes in the door inner panel and into the bottom bracket of the wing window.
Now slide the door window forward into the wing window channel.
Put the door window felt channel into the door frame starting at the top of the wing window and work your way around to the back. Be sure and push up on the felt channel as you go around the corner. Do not put it into the inside of the door yet.
Put the rear glass guide/channel up into place and put the ¼” machine screw in at the top by the door latch but do not tighten it up.
Insert the felt window channel down inside the door and press it into the remainder of the door frame and rear glass guide/channel. Push the rear glass guide/channel in against the window glass and put the two ¼” machine screws through the bottom holes in the door inner panel into the bottom bracket of the glass guide/channel. Now tighten all of the machine screws up and try the window to see how it works.
I hope I haven’t forgotten any steps in the process and if I have I hope someone points them out.
LockDoc
Leon
Old 10-09-2014, 11:04 PM   #5
kcsa75
kcsa75's Avatar
LockDoc
I just put two doors together. This is exactly how I did it.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 10-10-2014, 08:29 PM   #6
57larry
got it installed today. thanks for the help guys
Old 10-10-2014, 11:06 PM   #7
LockDoc
LockDoc's Avatar
No problem. Glad you got it...
LockDoc
Leon
