Old 10-09-2014, 05:27 PM   #1
Jonathans55
55 second series grill removal
Starting the drivetrain replacement in my 55. I was going at a pretty decent pace on deconstruction when I got to the bottom bolts on the grill. Middle 3 no problem. Outside 2 im wondering to myself how the hell do these come out.
Jonathans55 is offline   Reply With Quote
Old 10-09-2014, 05:32 PM   #2
Jonathans55
Re: 55 second series grill removal
It's right above the frame on both sides. And one hell of a tight spot.
Old 10-09-2014, 05:35 PM   #3
Jonathans55
Close up
Old 10-09-2014, 06:07 PM   #4
Jonathans55
How do these even get here lol
Old 10-09-2014, 08:43 PM   #5
Ratpin
Ratpin's Avatar
Hard to tell by the pictures. Wobbly socket maybe?
Where there's a will there's a way.
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 10-10-2014, 11:46 AM   #6
_Ogre
_Ogre's Avatar
8 bolts hold the whole front clip on; 2 lower rear fender, lower rear inner fender, upper rear fender and core support
the front clip comes of in one piece, 55-7 can leave the hood in place, 58-9 hood is integral to clip and needs to be removed
then the front end is a lot easier to disassemble, you'll probably figure the re-assemble sequence through dis-assembly
someone posted a factory assembly pic a while back of the front clip being installed in one piece
shop air compressor timer
