Old 10-10-2014, 12:14 PM   #1
73GMC10
73GMC10's Avatar
Any1 know the socket size for 14 bolt axle nut?
Since all the studs are trashed from the previous owner running on loose and washered lug nuts I need to take that big 3/4 ton 14 bolt rear end drum out to replace the studs, I cant seem to find a parts store that can help me on the size of the socket for it let alone even have them. any ideas on the size and where I can snag one?
73GMC10 is offline   Reply With Quote
Old 10-10-2014, 04:53 PM   #2
notallthere
Re: Any1 know the socket size for 14 bolt axle nut?
Are you talking about the keyed nut that holds the hub in place?
If so:
http://www.summitracing.com/int/part...a/applications
notallthere is offline   Reply With Quote
Old 10-10-2014, 09:01 PM   #3
73GMC10
73GMC10's Avatar
If so:
yes that is what im looking for, I think the one I need is the 2-5/8 when I went to the tool place I found today it had the 2-5/8s one and it said on it for 73-81 gmc 3/4 ton and 1 ton axles so fingers crossed thankyou for the link I hope I have the right one
