Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-10-2014, 04:38 PM   #1
rossboss
rossboss's Avatar
barn door hinges?
I know that the top hinges are different then the bottom, I believe that the bottoms are physicaly longer. Is there a difference from one side to the other.
I'm being told that the bottoms will only go on one way and the door pins are pointing up. That doesn't sound right to me, I pretty sure all the pins were facing down when I dismantled the doors. Would someone look at there door pins and let me know what direction they are facing.
rossboss is offline   Reply With Quote
Old 10-10-2014, 10:54 PM   #2
jweb
jweb's Avatar
Re: barn door hinges?
Just checked a spare set of barn doors I have and all the hinge pins are installed from the top.
jweb is offline   Reply With Quote
Old 10-11-2014, 01:59 AM   #3
spacedebris
same with mine. "Head" of pin rests on top. Seems to me if it was the other way around it would invite the possibility of the pin falling out.
Little hard to see, but I found a pic I took a while back that sort of shows the hinges...
spacedebris is offline   Reply With Quote
