Brake booster vacuum
I've fitted a booster under the cab but don't know where to connect the vacuum pipe to on my sbc350. Can anyone advise? Thanks
Re: Brake booster vacuum
Intake manifold should have a plug at rear of manifold
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
Ah I see, that maybe where I thought the fuel was gonna go in. Holley 4 barrel.
There is a port in the intake runner between the carb and dist. You can get the tee fitting at auto store. Big one goes to the vaccum booster, small to auto trans vacuum modulator if there is one. Dist is feed from port in carb. Big fitting at the back of the carb is for PVC valve from valve cover.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Most Holleys have a 3/8 port at the rear that will serve vac boosters and/or PCV.
I have a 454 with the thumper cam. the engine will not generate enough vacuum to operate the power brake booster.
I mounted the vacuum pump under the cab and the tube from the pump direct to the power brake booster. This pump is electric, noisy, runs a lot, vibrates, and you have to make sure the the electrical connection stays connected. |
Is that 3/8 BSP?
I am not sure what you mean?
Most Holleys have a 3/8port at the rear that will serve vac boosters and/or PCV.
![]() Join Date: Jul 2007
There are some belt driven vacuum pumps out there designed to go on Diesels in pickups that would adapt easily.
If I was running power steering I'd seriously consider a hydroboost setup and not worry about vacuum.
I'm not running power steering
Sorry, I did not read it thoroughly. I used the vacuum pump because my Thumper cam, edelbrock carb and the intake manifold would not put out enough vacuum to operate the power brake booster. The only vacuum I need is for the power brakes and the vacuum pump gets the job done. I do believe that the hose is 3/8" as you asked. The power brake unit is also under the cab and it is a short run. I can not see using vacuum for any function going forward or I would install a vacuum reservoir between the pump and the power brake booster.
#13 |
I don't think he is having an issue with low vacuum, just wants to know where the hose goes. Most manifolds, even after market, come with the port I showed. GM sold millions of car using it without any problems. It is where I ran mine under floor booster hose to, works great.
#14 |
Yeah, I haven't got anything being a project that I've taken over, thanks
#15 |
The carb is too close to the hole to screw a Tee in there. I might have room to screw an elbow, then the Tee
#16 |
Can you take a photo like Orrie's view? I am curious, too.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
#17 |
Best picture I have at the moment
#18 |
Yet another reason to hate Holley carbs. Elbow and a Tee it is. Make sure there isn't an open fitting/threaded hole on the back of the carb base plate.
Old Crow '54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ |
#19 |
Or there is plenty of room to put the carb on a spacer plate, would improve fuel delivery too.
#20 |
I'm gonna put a 3/8 plug in that hole & connect the booster hose to the outlet at the back of the carb on the spacer. I'm also gonna come off a smaller outlet at the front to go to the gearbox.
#21 |
There's a charcoal filter that goes in the vacuum line to the booster. I've read that you should have one or the gas fumes shorten the life of the booster. They're cheap so not a big expense, and readily available. Here's a link if you are not familiar with what I'm talking about.
https://www.google.com/?gws_rd=ssl#q...booster+filter |
#22 |
I have seen one fitted to a truck & I wondered what it was. That link isn't working for me
#23 |
It's just a thought but I've had to remove the carb to put a T in that spot when I ran Holley carbs on my truck.
If you don't have an automatic you wouldn't need a T though and an elbow or straight fitting would work.
#24 |
#25 |
Russell Good point, now I need to add it to the to do list..
