Old 10-10-2014, 06:03 PM   #1
Guy Dudebro
Hose from water pump to cab, can I cap it?
I'm flushing the coolant and changing hoses on my 67 c10. I yanked out the old air conditioning unit (or the parts left) and noticed this hose from the water pump to the cab. Can I put a cab on the water pump and take off this hose? What's the function for this hose? Any help is appreciated.
Guy Dudebro is offline   Reply With Quote
Old 10-10-2014, 06:29 PM   #2
tinlid
Re: Hose from water pump to cab, can I cap it?
Those hoses are for your heater. If you decide to take them off, run one between the intake and the water pump.
tinlid is offline   Reply With Quote
Old 10-10-2014, 07:10 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You won't have any heat either.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-10-2014, 07:10 PM   #4
mechanicalman
Do what tinlid said so you have a thermostat by-pass. Saves on cracked heads.
mechanicalman is offline   Reply With Quote
