Old 10-10-2014, 07:24 PM   #1
honess8290
honess8290's Avatar
wiring issues
So I just got this blazer from a fellow board member and while it's a great start I'm having Iissues figuring out where my wires go seeing how the ends are cut off.. anyway it's a 72 blazer with a 350..I've circled the 5 wires I need the help with thanks guys
honess8290 is offline   Reply With Quote
Old 10-10-2014, 08:58 PM   #2
jaros44sr
jaros44sr's Avatar
Re: wiring issues
IIRC, left side of that plug is all engine stuff, right side is headlight harness stuff. There is a great colored wire diagram down in the electrical forum, up at the top. But, if you can t figure it out, i ll look at mine tomorrow
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-10-2014, 09:05 PM   #3
honess8290
honess8290's Avatar
Re: wiring issues
Yes sir I got the right side all hooked up today. I will take a look at the electrical section thanks
Old 10-11-2014, 09:12 AM   #4
honess8290
honess8290's Avatar
Re: wiring issues
I looked at the diagrams in the electrical section but when I blew them up they were too blurry to read.
so if you could look at yours I'd appreciate it. .thanks Jim
Old 10-11-2014, 11:00 AM   #5
jaros44sr
jaros44sr's Avatar
Re: wiring issues
Let me know if you can read this one....what color wires do you have, and check to see if they are in good condition, no sense burning your truck to the ground
Any questions just ask
Screenshot_2014-10-11-10-51-48 by [url=https://www.flickr.com/people/97391199@N06/
SAFETY FIRST
AS usual, off topic
Jim
Old 10-11-2014, 01:47 PM   #6
honess8290
honess8290's Avatar
Re: wiring issues
Top two are tan and green.. middle is pink.. and the two on bottom are black wit thin white strip and a larger purple wire..
Old 10-11-2014, 02:14 PM   #7
jaros44sr
jaros44sr's Avatar
Re: wiring issues
OK, right now i got my head wrapped around this.....i ll see if i can help you in a couple hours
20141011_141033 by [url=https://www
SAFETY FIRST
AS usual, off topic
Jim
Old 10-12-2014, 08:03 AM   #8
jaros44sr
jaros44sr's Avatar
Re: wiring issues
Sorry, date w / wifey.....
Tan- brake warning light
Purple- starter
Pink- usually switched 12+, but i have to look, mine has been modified
Black/White- don t see one at your location
Green- horn, but there is lt. green and dk. green at that location. Looked again, probably temparture wire
This info. is from wiring schmatic. I ll look further for the black/white.....found a b/w on the othe side of plug, the one that has a bolt in it
SAFETY FIRST
AS usual, off topic
Jim
Old 10-12-2014, 08:20 AM   #9
jaros44sr
jaros44sr's Avatar
Re: wiring issues
My guess is coil, but can t say for sure b/c i now have 8 coils. Do you have a ballast mounted on the firewall, or HEI distri.?
Someone should stop by and confirm
SAFETY FIRST
AS usual, off topic
Jim
Old 10-12-2014, 08:40 AM   #10
honess8290
honess8290's Avatar
Re: wiring issues
Thanks for the help Jim and your we're right it was the coil.. I was also trying to figure this out with my two helpers. 4&5 year Olds sons.. good luck with your wiring. David
Old 10-12-2014, 09:10 AM   #11
jaros44sr
jaros44sr's Avatar
Re: wiring issues
Glad i could help you out. Thats where my sons started at, they became mech. engineers, good father/sons time in the workshop.Enjoy them, they grow up quick
I wish i only had 5 or 6 wires to deal with
SAFETY FIRST
AS usual, off topic
Jim
Old 10-12-2014, 09:58 AM   #12
honess8290
honess8290's Avatar
Re: wiring issues
They already are.. I've bought 3 blazers 2 1970's and this 72 my plan is to have them help me build them and give them to them for their first cars..
