Post Whore
![]() Join Date: Mar 2013
1966 chevy truck spotlight install.
So....Intro...Installed a spotlight on my truck. I took as many photos as I could, so....Here goes....
First step. Drill the two holes to hold that bracket in place...This requires an 1/8 inch drill bit. The bracket will only fit right in one spot...so perrty much just set the bracket on the piller and move it around until it sets in place....then..make the marks for your two mounting holes and then drill them.....
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Post Whore
Re: 1966 chevy truck spotlight install.
Next...mount your bracket firmly with the screws and install the pilot bushing( Picture 2..what my finger is touching)...and carefully with a 1/2 inch drill bit drill the hole ALL the way though...DON'T take the bracket off the drill the interior whole! The pilot bushing and bracket act as a guide. Install the gasket and bracket and your results are so! Picture 1. Picture 3 shows the drill.
Post Whore
Now the fun part! Installing the spot light...Fist remove the handle. Sorry...No pictures on that....and then slide through...results..Picture 1. Outside and inside pictures...Picture 1 and 2.
Post Whore
Then...install the interior grommet...bracket....and holder...then install the handle...and WALLA!!! Yer sitting there wonder why it took so long. lol
Post Whore
Now grab some coffee and a folding chair an sit back and admire yer work!
Nice work! I always thought you needed a fixture to drill the hole for a spot? No interference with the hood or door? Does the spotlight work? Can you point it any direction you need?
Kool...more details on the spot light..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
![]() Join Date: Mar 2011
Congrats on getting the spotlight mounted up and a great write up. It looks killer on there.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
Great job & write up TJ! Looks really good all mounted up, now you need to do one on a '60-'63 cab so I can see how to install one on my rig
#10 | |
Post Whore
#11 | ||
Post Whore
Thanks! I'll see about getting some more pics up about it.
Post Whore
Edit. Here's a picture I forgot to post....This is the whole in the interior.
#13 |
do you have any clearance issues with the steering wheel and hand placement?
what spotlight kit did you use?
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
#14 | |
Senior Enthusiast
Nice job TJ!
http://67-72chevytrucks.com/vboard/s...nity+spotlight
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#15 |
Post Whore
No clearance issues. I bought a kit from Unity USA...the 187 L bracket kit.
#16 | |
Post Whore
#17 |
Post Whore
#18 |
Kid's Mechanic
What was the total cost when finished ?
#19 | |
Thanks for the '60-'63 link markeb01, I appreciate it!
Murph Quote:
#20 |
Post Whore
Got the NOS spotlight for $125 off a ebay...Bracket kit from Unity USA was $66.95....$17 to ship...so...$208.95 total.
#21 |
SIR
..great work t.j.!!!....remember ...no fair "spotting" .....
66long low fleet http://community.webshots.com/user/LVNR66 |
#22 |
Kid's Mechanic
#23 |
Post Whore
Ok...so over a month and I still haven't hooked up the electrical on the light...mainly cause there is no place on the harness board to hook it up...it has the option, but no hook up....but I did test the light and it works.
#24 |
Senior Enthusiast
I don't know if the fuse panels changed by 1966, but here's the 1960 instructions on how to connect wiring from the Accessory Installation Manual:
#25 | |
Post Whore
