Old 10-11-2014, 07:24 PM   #1
Brettr
door jamb switch location?
Hi; Can anybody out there give me the proper location for the installation of the door jamb switches, into a 1968 C-10, which activate the under dash courtesy lamps? The truck I'm installing these is didn't have them originally?
Thanks for considering,
Brett
Brettr is offline   Reply With Quote
Old 10-11-2014, 07:43 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: door jamb switch location?
Here's one thread that may help. Courtesy lights should work off the dome light switches if your truck is equipped with them. Switches were not included with the lower trim levels, for at least the early years, in which case, the dome light only worked from the headlight switch.
http://67-72chevytrucks.com/vboard/s...d.php?t=620438
And... WELCOME TO THE FORUM!!!!
FirstOwner69 is offline   Reply With Quote
Old 10-12-2014, 09:40 AM   #3
hugger6933
I may have missed it cause I hurried through the other post but the post also has a center punch mark on it to drill the starting hole for the dome lamp switch. That center punch will put you in the correct location. Welcome to the site. Jim
hugger6933 is offline   Reply With Quote
