Old 10-11-2014, 09:35 PM   #1
Tennessee Bowtie
Tennessee Bowtie's Avatar
1969 c10 fleets idea 5.3 ls swap with 4l60e!!!!
Hello to all. I am going to post some pics of my build. I am currently about to start sanding and painting Fram and crossmember. I will post pictures of prior and or current and will make a parts list as well.
NOT INSTALLED YET:
5.3 ls
4L60E
early classics crossmember
Early classics ls mounts and towers
Wait4meperformance tune and moded harness
painted valve covers by urs truly
current performance ceramic coated headers
classic parts body and radiator mounts
ORIGINAL:
inline 6
3 spd column shift
I had to remove the trans crossmember that was riveted in. Let me start with that is a horrible design however nothing a air Hamer and chisel couldnt take care of. I also pulled the front clip to make easier access. I am currently looking for power brakes and power steering box as well as a stock auto steering column. As of now this is where I am.
Tennessee Bowtie is offline   Reply With Quote
Old 10-11-2014, 09:39 PM   #2
Tennessee Bowtie
Re: 1969 c10 fleets idea 5.3 ls swap with 4l60e!!!!
Here is a few
Old 10-11-2014, 09:45 PM   #3
Tennessee Bowtie
A few more. Also can anyone tell me y my pic were sidways.
Old 10-11-2014, 09:48 PM   #4
Tennessee Bowtie
This crossmember was a b****.
Old 10-11-2014, 09:52 PM   #5
Tennessee Bowtie
Only did this post to have post number 69!
Old 10-12-2014, 10:08 AM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
Id paint he rest of the engine too. Corroded aluminum isn't pretty. Makes the plastic easier to clean also.
A current pic and 5 years ago
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-12-2014, 10:55 AM   #7
Tennessee Bowtie
Does anybody know how to change title my phone auto corrected fleetside
Old 10-12-2014, 11:04 AM   #8
GoaterAz
GoaterAz's Avatar
I am in the process of removing this crossmember, as well.
How did you get the upper, rear rivets out?
I'm pretty sure I have enough room to grind/cut off the head, but I have no idea how I will pound it through. There is like 2" of room with the cab on haha.
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 10-12-2014, 04:41 PM   #9
Tennessee Bowtie
Air hammer man. Air hammer. Go to harbor freights and get the long chisel set. Works wonders. After the head is off I jammed the air hammer in between the Fram and crossmember and it pushed the rivets out. I had to cure one end though to get it out. If u decide to cut It just cut on the middle make it easy on ur self.
Old 10-12-2014, 04:44 PM   #10
Tennessee Bowtie
Wire brushed and painted today. Hopefully tomorrow motor will be getting dropped in.
Old 10-12-2014, 06:04 PM   #11
Tennessee Bowtie
So i used the paint and rust remover disc and i also used a wire brush on frame and i can tell u thst the wore brush is definitly the way to go. Tomorrow will be installing mounts and trans crossmember.
Old 10-12-2014, 11:53 PM   #12
Heylookitsdylan
What paint did you use? Did you prime it as well?
Heylookitsdylan is offline   Reply With Quote
Old 10-12-2014, 11:59 PM   #13
Blown06
Blown06's Avatar
That's a clean truck man. Gonna enjoy watching this project.
Blown06 is offline   Reply With Quote
Old 10-13-2014, 09:02 AM   #14
Lees68GMC
Lees68GMC's Avatar
So my truck went from Old Blues dirt ball 307, to a later model 4 bolt 350 & Turbo 400, to a 2005 Vortec 5.3 & 4L65E. My buddy Tim is a one man wrecking crew, he does these Vortec conversions in days, all by himself essentially and the work is great - Lee
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 10-13-2014, 01:19 PM   #15
SierraMtns
SierraMtns's Avatar
Very nice. Which brake master are you running?
SierraMtns is offline   Reply With Quote
Old 10-13-2014, 04:29 PM   #16
Tennessee Bowtie
I need a brake booster as well. But anyhow I got some progress today.
Old 10-13-2014, 04:34 PM   #17
Lees68GMC
Lees68GMC's Avatar
2001 Chevy S10 Dual Diaphragm & proportioning valve for Disc front, Drum rear, from U-pickit. Really challenging inside, we built new pivot point and pedal support structure over the steering column, under dash to use a 75 C10 brake pedal complete, it was a pain. The up shot is you can practically stand the truck on it's nose when you really slam on the brakes, Stops like Right Now!
98 Chevy Blazer ZR2
Old 10-14-2014, 09:47 AM   #18
Tennessee Bowtie
My he add ers are sanderson headers sorry early I said current performance. That is who I bought them from.
Old 10-14-2014, 04:40 PM   #19
Tennessee Bowtie
Header pic and clearance. Also a pic of some crazy 45 ammo.
Old 10-14-2014, 04:55 PM   #20
DWilbur
what brand of header are you using.
DWilbur is offline   Reply With Quote
Old 10-14-2014, 05:12 PM   #21
Tennessee Bowtie
Sanderson I got mine ceramic coated from current performance at like 400 shipped I think. They are really awesome.
Old 10-14-2014, 05:23 PM   #22
DWilbur
What model number are they. I'm installing a 5.3 in my K20 having issues with the motor mount and what headers work. on C10 or C20 the engine mount hold the engine about 1.5" higher that what I have. I have a set of block hugger header that fit but I don't like the way they look. The Dough Thorley header look great but don't fit they are for C10 with different motor mount.
Old 10-14-2014, 05:33 PM   #23
Tennessee Bowtie
I used early classic towers and mounts they r like 230 and their crossmember was like 90 and then sanderson headers and all fits great. http://www.currentperformance.com
Old 10-16-2014, 08:46 PM   #24
GoaterAz
GoaterAz's Avatar
TN Bowtie, I wanted to say thanks! This really helped me out. I wouldn't have thought to wedge the air chisel between crossmember and the frame, I'd still be out there calling it the F word, haha.
This might all be second nature to some, but being my first build with limited tools/zero knowledge, this is all new to me and it's tips/tricks/advice like this that keep me coming back.
Me neither.
Old 10-16-2014, 09:16 PM   #25
Tennessee Bowtie
Np man I am glade I could help. I think u are the first one I have helped on here. Is that a porter built drop member?
