Old 10-11-2014, 09:44 PM   #1
Ziegelsteinfaust
Drive shaft failure.
I was driving my K20 to get pizza, and my DS failed. My truck is stock height with a stock DS. With 2.5 inches of compression on the slip joint available.
So as I went through a dip about 15 mph, and about 150 feet later my truck went pop.
I found a few pieces of broken cap on the street.
The U joints were on the frame I got the DS from, and all I did was grease them up with the install. When I inspected the DS I found plenty of grease in there.
So what should I look for as a failure point to prevent another tow home.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-11-2014, 10:39 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Drive shaft failure.
U joints fail. Maybe it was time?
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-12-2014, 09:02 AM   #3
crossfire84
crossfire84's Avatar
The answer can be that the u-joint series is too small for the application. Or possibly you are using an inexpensive parts store u-joint that does not offer strength. Maybe you are using a greaseable u-joint and it is breaking across the grease fitting hole. The corresponding yoke is damaged or distorted and causing premature failure.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 10-12-2014, 12:41 PM   #4
Ziegelsteinfaust
The DS was greaseable u-joint from the project frame I got, and likely what was installed in 1979. If a aftermarket u joint was used it would of been in the late 80's before it was parked from a tree hitting the cab, and parked. I do not see evidence of the u joint being anything but old though, and used. The cap that failed was broken in pieces, and I do not see damage on the + piece. I only quickly inspected as it was getting dark.
I will pull it off in a few hours when the chores are finished up. Of course it could of been the sound of 260HP 350 crate motor with bolt-ons that scared it to death.
